Suspension & Brakes Theory, alignment, spring rates....
KYB GR2 sits lower than Tokico blue
Old Mar 18, 2011 | 10:36 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Icon6 KYB GR2 sits lower than Tokico blue
Sorry, I don't have pics. Even if I did, one could not tell.
Anyone who have them in the past with the same set up, have you noticed this?
KYB GR2 seems to sit lower than Tokico blue shocks.
I recall this from my old 97 Civic on H&R Sport springs.
Trying to help someone out now. So maybe the question now should be, all shocks, in theory, should be the same, but they are not when installed on cars. Do all shocks have the same level of right height?
* I know Koni have adjustable perch. So this is for non-koni shocks.
Old Mar 19, 2011 | 05:40 AM
Red_Army's Avatar
Default Re: KYB GR2 sits lower than Tokico blue
seeing as how the springs decide the ride height more then the shocks that might be it too.
Old Mar 19, 2011 | 01:59 PM
night's Avatar
small diffs in bracket/perch welding location. are they pinch bolt with a slot or with the key plate welded to the back of it?
Old Mar 21, 2011 | 09:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You would need to lay one of each shock (plus an OEM one preferably) side-by-side and compare the distance from the fork bearing point (bottom edge of brake line bracket) to the spring perch. This distance plus the spring determines the ride height.
GoLowDrew
Mar 19, 2011 07:33 AM
TonyRomo
Suspension & Brakes
Apr 10, 2009 10:38 PM
Libertariat
Suspension & Brakes
Aug 31, 2006 03:17 PM
aznfab
Oct 18, 2003 09:39 PM
Seedc2
Oct 29, 2001 12:22 AM
