Door Lighting
On my 1991 Honda Accord their are courtesy lights at the bottom of the doors. My driver side light works. While the passenger side doesn't. I change the light bulbs and still nothing. So then I used a mutimeter and there was no power. I took the door panel off and the wires are all their. I want that light to work and was wondering how to fix it.
its most likely worn out wire , you know where the door bends theres a rubber sleeve, usually wires break there, i had speaker going of and on in my drivers door, and turns out i had a broken wire in that little section, you can try pulling out pins from the stop it will let you open door little more for access
BrotherAli
Mar 6, 2016 09:56 AM
draperj09
May 14, 2008 08:01 PM
