Engine Won't Stay On!:(...Please Help!
Okay Guys
I recently bought a 99 Honda Civic EX and I can't figure out the problem
The engine only stays on with the battery
I change the alternator but it does not keep the engine on when I remove the the battery cable.
I checked all the fuses and relays
so if you guys know what the problem probably is ....let me know
I will appreciated very much thanks.
Check if there are any open connections. May be a wire from the subs touching the body of the car. A bad alternator. Check your spark plugs, are they rusty loose or covered with oil? Do you have an anti theft system or alarm that could be causing this?
Okay Guys
the alternator charges the battery through the positive cable... and if your tryin to disconnnect to main ground from the battery your at ris of causon a voltage spike and damaging the ecu... and possibly other components like sensors and relays
ID_ten_T
Nov 2, 2004 11:24 PM
Ludeboi
Audio / Security / Video
Jul 8, 2002 06:18 AM
