whats the difference between these two?
Im trying to lower my 96 honda accord ex sedan just about 1.5"-2" but im stuck at wich one would be better and whats the difference the top one says coilover high low kit and the bottom one is just lowering springs i appreciate any help.
Don't bother with either. Save your money and do it the right way the first time.
Top, is coilovers. They allow you to adjust the height of the car.
Bottom:lowering springs, one set height.
Whats the right way? And do you know if these just go on stock shocks? Honestly i know nothing about these things i need as much info as possible thanks.
Yea but im kinda on a tight buget dont really wanna spend more than $150 to lower my car its just that my front end is really high compared to the back what would you guys recomend around that price range
You can't do **** with $150 Remember you still need an alignment after. Which will eat up half..
Save your money. You don't need to lower it you want to lower it.
Learn from my mistakes. I bought cheep stuff, and now 1 by 1 I have to replace almost everything I bought.
By all means, If you want to buy cheep coilovers than do it. But expect your shocks to blow, expect your car to handle and ride like ****. And expect people to point and laugh at you when you, when they see you bouncing out of your seat.
What are some decent coilovers? Id rather get coilovers since i can adjust the height of car wich is what i want im willing to spend more just depends how much it is. Taking any recomendations
I need to replace my shocks they make a crunch noise when i hit speed bumps do you guys recomend any decent shocks that i can replace and install the skunk2 coilover springs with them together im looking for inexpensive shocks any ideas?
there are vendors on this site with decent spring/shock combo's and decent coilover/shock combo in the market palce. dont forget if you lower the car or change anything int he suspension you will need an alignment
Koni STR.T would be good if they make them for your application.
You'll need at least $500 to get quality shocks, lowering springs, and an alignment to avoid trashing your tires.
From my exp., I'd recommend eibach sportlines. They run about $220 but could be foound on CL for like $100. Good springs. Ride wont be too bad.
jdm_steve
Suspension & Brakes
16
Jan 11, 2012 04:40 AM
naterocks21
13
Mar 26, 2010 09:02 PM
2003, accord, bumpers, coupe, differecnce, difference, end, front, health, honda, information, oem, replacement, sedan, si, systems, technology, whats
