Will a 96-00 hatch exhaust rear section fit on a 95 civic hb?
no, too long.
92-00 civics use the same header, cat, and midpipe.
92-00 hatchbacks use the same rear section.
92-00 2dr/4dr use the same rear section.
thnx for responding, but you kinda confused me. because you said its too long but then you said its the same. I have a rear section from my friends 98 hatch. i want to know if it will fit my 95 civic hatch.
this is wrong. 96-00 civics have the cat built into the header.
Sorry can't answer your question with %100 guarantee. I'm guessing you mean the axle over section? if it is stock, it will bolt up. the problem will be the length over or under the rear lip. if it's an aftermarket section... too many manufacturers have different connection measurements. take it to the muffler shop and they can fit it in 10 minutes.
My bad, I meant to say it will fit.
No, it's not wrong. Those pieces are unique to 92-95 cx/vx (b8/z1) and 96-00 lx/dx/hx/cx (y7/y5). You can replace them with a header/cat/midpipe from a 92-00 civic hatch/coupe/sedan and it they will bolt up to the rear section.
It says 96-00 Civics (as in ALL) have the cat built into the header. Only CERTAIN models, like the Y7, did so the blank statement is WRONG.
9civichatch3
Welding / Fabrication
Apr 7, 2011 06:17 PM
2000em1_civicsi
May 28, 2009 10:32 AM
