Lifeless rex?
Old Mar 18, 2011 | 05:44 AM
Honda_Mane's Avatar
Icon2 Lifeless rex?
Okay walk out to my crx this morning to start it.... relay kicks on, fuel pump kicks on, but the car does not turn over.......no clicking or anything? I tapped on the starter but had no result, so i thought maybe the batt was drained but my lights and radio work as well as all my dash lights. I had no time this morning as i was on my way to work. Just tryin to gather some other ideas. i did check all the fuses, however not the ecu window.
Old Mar 18, 2011 | 05:50 AM
dephtone's Avatar
Default Re: Lifeless rex?
I would start by checking to see if you are getting power to the starter solenoid.
Old Mar 21, 2011 | 04:59 AM
Honda_Mane's Avatar
tested starter selenoid 12.2v. tested the plug at the starter relay under dash had 11.6 so Im hoping that its just the starter relay. plug is four prong, anyone have a diagram of which terminals get connected?
Old Mar 21, 2011 | 05:19 AM
CRX Toad's Avatar
Check battery first, sometimes there is enough power to turn on lights etc but not start the car.
Old Mar 21, 2011 | 08:40 AM
Honda_Mane's Avatar
thats what i thought, but batt has 12.4v. With that i figure it is either the starter relay or the clutch switch. From what ive read the clutch switch is a pita to get to so we'll see. Nobody has a diagram or know what wires get jumped on the plug for the starter relay?
Old Mar 22, 2011 | 06:16 AM
Honda_Mane's Avatar
bump......NOBODY KNOWS HOW TO JUMP THE STARTER RELAY?????????
Old Mar 22, 2011 | 06:26 AM
maddix's Avatar
what does "jump the starter" mean?
Have you examined ground? i had the same problem. and solution was a earthing conductor.
Old Mar 22, 2011 | 08:39 AM
AlaskaREX's Avatar
You can bypass the ignition circuit by unplugging the connector (BLK/WHT) from the starter and running a jumper from the positive battery terminal to the starter solenoid terminal. Make sure the car is not in gear.
Perhaps a silly question and I apologise in advance for asking it but, did you clean the battery terminals or just measure voltage positive terminal to negative terminal? Whenever this happens to me it is usually dirty or loose connection at the battery terminals.
Old Mar 23, 2011 | 06:35 AM
Honda_Mane's Avatar
Under the dash there is a relay right above the hood latch. It has four pins, I want to "jump" this relay because I believe the starter relay is bad? Usually you can just fold a paper clip well this plug has four pins instead of two.
Old Mar 23, 2011 | 06:37 AM
Honda_Mane's Avatar
Batt has good voltage, as does starter. So just for ***** and grins I will clean them again and try to give the car a jump. Thanks for the info.
Old Mar 23, 2011 | 07:53 AM
Creator's Avatar
That is the main relay, near the hood latch. Usually when it goes bad the fuel pump will not work.
Old Mar 23, 2011 | 10:00 AM
Honda_Mane's Avatar
no matter how many times i repeat myself.............THE STARTER RELAY!!! Not the main, not the starter solenoid......It is called a starter relay. The relay you mention is under the dash mounted upside down, this relay however is right above the hood latch. google it if you have to.
Old Mar 23, 2011 | 10:49 AM
Creator's Avatar
After using the search option...I found that there is not a starter relay on EF's.
Old Mar 23, 2011 | 11:16 AM
Canadian_EF's Avatar
That black box that is sort of a b*tch to get out, right above the hood release lever?
Main relay.
Old Mar 23, 2011 | 11:33 AM
Creator's Avatar
I posted wrong info, it will have a starter relay. Just tryin to help you. I know your frustrated with the car, take it easy.
From what I've read, the starter relay rarely goes bad.(last post)
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/starter-relay-where-240083/
Which would most likely be why no one can answer your question about it.
Another thing to test is your clutch switch or starter switch. This post has some good info:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/wiring-rem-start-where-neutral-pos-switch-wire-lower-drivers-footwell-907664/
Old Mar 23, 2011 | 12:02 PM
Honda_Mane's Avatar
https://honda-tech.com/forums/showthread.php?t=240083
https://honda-tech.com/forums/showthread.php?t=907664
Thanks for info I have had a very hard time finding info on it? The clutch switch from what ive read is a pita to get to........ Anytime somebody says relay and ef in the same sentence everyone is like its the main relay lol. I have bought a main relay from honda about a year ago after having so much trouble with them. Cost me 80 bucks from honda...... Thanks to everyone who offered. Creator thanks for hookin me up with the other writeups mane.
Old Mar 23, 2011 | 12:03 PM
Honda_Mane's Avatar
Main relay.
EPIC FAIL...
91tegrals
Feb 12, 2012 09:03 PM
redefsir
19
Jan 28, 2010 08:46 AM
91akira
Nov 28, 2009 10:39 AM
91da_teg
May 14, 2009 05:56 AM
