d16 mini me code 4 limp mode??????
Old Mar 17, 2011 | 09:08 PM
ww3slayer's Avatar
Default d16 mini me code 4 limp mode??????
did a d16a6 block with d16z6 head in my 89 sedan all obd1 have a code 4 and am in limp mode dizzy works on friends car but not on mine was fine for first mile until i turned car off could timing be off or wiring have no power????
help please
Old Mar 18, 2011 | 04:13 AM
lazlong's Avatar
Default Re: d16 mini me code 4 limp mode??????
Code 4 is for the crank position sensor. Either the sensor is bad or a wire is bad/pinched. Pinched wires is one of, if not the most common problem I've seen with swaps.
If you think your not getting power to the dizzy then check for battery voltage by disconnecting the dizzy wire and putting the positive lead of the multimeter on it and the negative lead to body ground.
Old Mar 18, 2011 | 05:45 AM
dephtone's Avatar
Here is the Factory Service Manual troubleshooting for Code 4. I used this when I had code 9 and turned out to be code 4. Hope this helps you out.
File Type: pdf
Old Mar 20, 2011 | 03:14 PM
ww3slayer's Avatar
got it fixed my wiring behind the motor fell on to the axle and was shorting out thanks for the feed back
miguey310
Nov 21, 2010 09:24 PM
ys1civicsi
Jul 3, 2007 05:42 PM
ESPTUNING
Mar 28, 2005 07:24 AM
crashtest Sonny
16
Jul 8, 2004 10:41 PM
lsvtec42
Dec 19, 2001 10:11 AM
