Need help on finding OEM replacement parts!!!!
Old Mar 17, 2011 | 09:06 PM
b18c_dc2_davis's Avatar
Default Need help on finding OEM replacement parts!!!!
Like the title says,
A couple of light bulbs are out in my AC control unit.
The left and the right one should be red like the middle "A/C" when the light is on.
Which one is the right one for the replacement light bulbs??
And I also looking for the brake duct shield for my RSX.
Is it the number 15?
All suggestions are welcome.
Thanks
Old Mar 17, 2011 | 10:00 PM
rjmq06's Avatar
Default Re: Need help on finding OEM replacement parts!!!!
if its the bulbs it will cost you 5 bucks tops on acura dealership
Old Mar 18, 2011 | 02:10 AM
It's about 5 bucks for each one (number 7 and 10 in the pic) but im just not sure which number is the right one, cos someone told me the buttons (5,6,9 in the pic) should have the light bulb in there.
Old Mar 18, 2011 | 03:09 AM
rjmq06's Avatar
i think the 7 and 10 is for the whole thing
maybe you should ask the dealership bout this
Old Mar 18, 2011 | 06:52 PM
sandracer's Avatar
You are looking for #10. Just replaced mine last week. Part # 80629-S04-003. Cost me $3.89 each from Delray Acura. Or you could order some 3mm Neo-Wedge LEDs from superbriteled.com for about half that.
Old Mar 18, 2011 | 08:43 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
if you lived closer I have brand new still in the bag bulbs.
Old Mar 18, 2011 | 09:04 PM
How many of the number 10 do I need in my situation?
Did you take out the whole control unit to replace the bulb?
I just look at the diagram and there are only two bulbs inside the control unit but three colors. How about the indicator lights?
Old Mar 18, 2011 | 10:46 PM
sandracer's Avatar
You would need 2 of them. To replace them you pop out the control assy, and remove the rear cover. It's held on by several small phillips screws. You will see 5 total bulbs, 3 small & 2 larger. The 3 small ones are the lights for the *****, so you would change the 2 outer bulbs. The indicator lights are part of the switch & are not replaceable without soldering.
Old Mar 21, 2011 | 09:26 AM
s_mcgrath87's Avatar
you could go to radioshack and buy the led bulbs
CivicVX94
Jan 26, 2006 09:20 PM
Nishant
Jul 24, 2003 06:31 AM
Back in Black
Jun 22, 2001 06:27 AM
