96 ACCORD POPPING EXHAUST WHILE CRANKING
Old Mar 17, 2011 | 06:09 PM
RACER83's Avatar
Icon6 96 ACCORD POPPING EXHAUST WHILE CRANKING
Hi,
96 Accord LX 4cyl, manual tran. Never has a problem starting from cold but if I go back to the car 10-30 minutes after shutting it off, it cranks, but won't start. While cranking, it now makes a soft popping sound out of the exhaust and occasionally slightly hesitates during cranking but wont start. Battery, plugs, wires are fine. Garage has checked fuel flow and told me timing was OK....they can't solve it. What's strange is when I wait an hour so that engine is completely cold, it starts again....no problem. After driving for a while then shutting the engine off, it will start again straight away. It's only after a 10 to 30 minute cool down that it wont start. Any ideas please. Thanks.
Old Apr 12, 2011 | 11:08 AM
ttcheung97's Avatar
Default Re: 96 ACCORD POPPING EXHAUST WHILE CRANKING
did you ever solve the problem? I'm having the same problem. Everything is basically new except for the ignition switch.
Old Apr 13, 2011 | 06:28 AM
RACER83's Avatar
Hi ttcheung97,
I had a number of things done that eventually fixed the problem. (just a few days ago) The first was to make sure there was sufficient fuel flow from the fuel pump. Then, I took the EGR Valve off, cleaned any carbon deposits including the ports under the fuel rail......BUT, the 3 items that finally cleared up the problem were, new spark plug ignition wires, rotor and distributor cap.
Apparently the spark was very weak, so I would definitely start with that first.
Hope it helps you.
(the first mechanic thought my wires were OK, but he never solved the problem, the 2nd mechanic
thought they might be part of the reason for the weak spark, so they were replaced)
jooanyenna
Jan 5, 2014 10:27 PM
sf89lx
Dec 8, 2012 01:50 PM
Caleb0123
Aug 27, 2011 05:42 PM
xlogit3k
Apr 26, 2008 11:43 AM
DDRnrgONxtc
Sep 20, 2006 09:47 AM
