MN DC4 Integra 1999 $4800
Clean title 1999 acura integra DC4
Built motor 2300 miles
gsr b18c1 block
ls cranks and rods
ACL bearings
CTR pistons 82mm bore
itr head
skunk2 pro 2 cam and gears
dual valve springs
retainers
70mm throttle body
tri-y headers
aluminum radiator
gsr tranny
act no spring clutch
type R flywheel
test pipe
yonaka exhaust
short throw shifter
itr cluster
itr panels
itr rear seats
ls cloth front seats
itr wing
itr front lip
shaved side molding
rota slipstream rims w/ nitto tires
d2 coilovers
HID's
C-Pillar strut bar
OBD2 - OBD1 harness
HANDCOMMAND ECU
NO RUST
the car is tuned and running on E85 gasoline making 205.2 max whp and 135max torqe.
custom base map, revlimit @ 9krpm, tuned by DPperformance
bads: Rock chips, dents, upper radiator support was cut off by last owner, cracked rear wing, crack windshield. also has ITR stickers
Had MR Fin's on roof but removed.
might forget some stuff. but all in all it really need is a fresh repaint and a little clean up.
like i said i'm looking for $4800 or trade's
willing to trade for a clean car with cash on my end.
gsr b18c1 block
ls cranks and rods
ACL bearings
itr head
dual valve springs
retainers
70mm throttle body
tri-y headers
aluminum radiator
gsr tranny
type R flywheel
test pipe
yonaka exhaust
short throw shifter
itr cluster
itr panels
itr rear seats
itr wing
itr front lip
shaved side molding
d2 coilovers
HID's
C-Pillar strut bar
OBD2 - OBD1 harness
HANDCOMMAND ECU
NO RUST
