WIRING LED STRIP TO DOME LIGHT? EK
Old Mar 17, 2011 | 05:13 PM
anstitute's Avatar
Default WIRING LED STRIP TO DOME LIGHT? EK
Anyone able to wire some cheapo Ebay led strips to sync w/ the dome light? My lighting everywhere (cluster/dome/dash) is dangerously poor...
There's some info online, but nothing for our EKs...at least nothing an electrical noob can comprehend.
Thanks. I appreciate the knowledge!
Old Mar 17, 2011 | 05:32 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: WIRING LED STRIP TO DOME LIGHT? EK
I don't know, but the dome light is only 7.5 or 10 amp IIRC.
Old Mar 17, 2011 | 05:37 PM
grumblemarc's Avatar
The Grumpiest
Why don't you just get the LED lights that actually plug into the light socket instead of hacking wires?
Old Mar 17, 2011 | 06:59 PM
Linked's Avatar
he wants lights to sync WITH the dome light, not replace the dome light
run a relay on the dome light circuit so it controls led strips around the car
places to put led strips:
under the dash in the foot well
under the doors so they light up the ground
under the rear seat
and replace your dome light with an led bulb, and find the map light that they have for EKs
Old Mar 17, 2011 | 07:53 PM
anstitute's Avatar
Hey Linked,
Do you have any idea (what color) the circuit is?
I just replaced the dome w/ an LED....not all that great though.
Old Mar 17, 2011 | 08:00 PM
Linked's Avatar
if you replaced it with only an "LED" that wont be enough of course,
or unless your talking about an LED cluster bulb, then you might have a shitty brand
but the color of the power wire you put the relay on is white/blue
comes from the under dash fuse box, i believe up the front driver side pillar and to the dome light, may be easier to splice into right under the dashboard
thecruzs2007@yahoo.com
Acura TSX
Aug 24, 2013 10:32 AM
doug118
Jul 5, 2010 09:02 PM
