OH 1995 Civic Coupe GSR Swap (built)
Old Mar 17, 2011 | 05:06 PM
Amerika's Avatar
Default 1995 Civic Coupe GSR Swap (built)
Looking for $11,000 or best offer or trade for somthing with 4 doors car needs to go cash talks. Cell number is 419-786-9308 text for pictures Car has no problems whatsoever and needs nothing.409whp and 276 ft/lbs less then 200 miles on the last tune. Still gets 30+mpg. I just had a baby and need a four door (want a GTP) for now. Pics are attached. Only difference is it doesnt have a carbon fiber hood and now has a new battery and oil catch can.
1995 Honda Civic EX Coupe Paradise Blue-Green Pearl – KBB Value $4000
103,xxx miles on chassis
8xxx miles on Built Motor and Turbo Kit
NO RUST
Power Sunroof
Power Windows
Power Door Locks
Acoustic Research 6 speaker with Pioneer deck
Rear Seats Removed
AC and PS Removed
CC Disconnected
Wire Tuck in Engine Bay
B18c1 GSR Complete Swap - $3500
6 pt Roll Cage w/ 4 pt Racing Harnesses - $2500
Alarm with Remote Unlock - $250
Entire Car including Engine Bay Freshly Painted - $1500
C&R Radiator - $250
Slimline Fan - $125
Mishimoto 80*C Fan Switch - $20
MSD Coil, Cap and Rotor w/ Accel 8.5mm Wires - $125
Phantom Boost, EGT, and Oil Pressure Gauges w/ AutoMeter Triple A Pillar Pod - $375
Apex-i Turbo Timer - $100
SlowMotion Motor Build – $4300
Disassemble motor
Clean head, block and crank for machine shop
Bore and hone block
Micro polish and balance crank
Multi angle valve job
True head
Blue print bottom end
Assemble head
Assemble long block
Bottom End
CP Pistons 9.0:1
ACL bearings
OEM water pump
OEM oil pump
OEM timing belt
OEM bottom end gasket kit
Cometic head gasket
ARP head studs
Head
Mild Port and Polish - extra $550
Crower Valves
Crower Springs
Crower Retainers
OEM Valve Seals
Stock GSR Cams
Hondata Intake Manifold Gasket - extra $50
Slow Motion Cam Seals – extra $25
Turbo Kit - $5000
Slowmotion Ram Horn Turbo Manifold
T3/60-1 – extra $100
Precision 600hp Intercooler – extra $150
Tial 38mm Wastegate
Greddy Type RS BOV
Aluminum Intercooler Piping Kit
Neukin 3in Stainless Steel Down Pipe with 8in flex and Dump Tube - $400
"Extended 3in Down Pipe" (ends behind front seats)
Hondata S300 - Dyno Tuned by Corey Parrish at SlowMotion MotorSports
409whp 276 ft lbs
Fuel System
Stainless Steel Braided Fuel Lines From Firewall - $100
680cc Injectors
Walboro 255 Fuel Pump
Golden Eagle Fuel Rail - $130
Big *** Fuel Filter
Drive Train and Suspension
Stock LS Transmission - $400
B&M Short Shifter - $150
ACT XT-R6 Clutch - $450
Omni Power Coil Overs - $200
Integra Struts
Slotted Rotors - $150
Sound System-
2 sets of Polk Audio component speakers
Pioneer Deck
File Type: doc
File Type: doc
File Type: doc
File Type: doc
Old Mar 18, 2011 | 10:28 AM
srt4mike's Avatar
Default Re: 1995 Civic Coupe GSR Swap (built)
Bump for viewing.
Old Mar 20, 2011 | 03:37 PM
Amerika's Avatar
bump
pearlcfcivic97
Oct 2, 2011 02:03 PM
Amerika
Mar 17, 2011 08:37 PM
swainsol
Southeast (Sales)
Sep 15, 2008 07:31 PM
swainsol
Sep 6, 2008 11:32 AM
slixxracing
Jan 26, 2006 11:55 AM
