Squeaking
What's up guys...
I'm trying to figure out where the hell this squeaking noise is coming from on my car. It's noticable only while shifting gears, and when the accelerator is down a certain amount it is continuous, but during those times it's quite loud (and annoying)
It sounds like it's in the area of my front right wheel, and it sounds like a noise caused by moving in a circular motion which is why I think that it's related to the wheel. Any ideas what it could be???
It could be your brake pads you might want to check on those..
The reason being this is because most brake pads have this little pin that causes squeeking to alert the driver that the pad is wearing out and needs a new one.
Oh yeah and while checking on them make sure to clean it out because there might be some small rocks or **** stuck in there...
[Modified by MaRkO, 10:51 PM 9/26/2002]
I had a squeek like that after I fiddled around with my exhaust. It only happened at real low rpms. You may also have a rock in the dust shield on the brake disk.
pcguy760
Apr 8, 2007 03:52 PM
