is it necessary to resleeve the block if running 82mm pistons
Old Sep 26, 2002 | 07:20 PM
lazyguy's Avatar
Default is it necessary to resleeve the block if running 82mm pistons
i wanna take it as far as i can with out sending the block out to be resleeved
is 82mm possible?
Old Sep 26, 2002 | 07:32 PM
sgT's Avatar
sgT
Default Re: is it necessary to resleeve the block if running 82mm pistons (lazyguy)
on b16/b17a/b18a/b/c yes
Old Sep 27, 2002 | 08:13 PM
lazyguy's Avatar
Default Re: is it necessary to resleeve the block if running 82mm pistons (sgT)
so there will be absolutely no problems with the walls even with a 9k reving motor?
i just want to make sure before i go do something stupid
thanks
sgt
Old Sep 27, 2002 | 08:51 PM
polymath's Avatar
planning on n20 or boost? I would say no. Otherwise, don't think there would be a prob.
Old Sep 30, 2002 | 07:38 AM
lazyguy's Avatar
Default Re: is it necessary to resleeve the block if running 82mm pistons (Coyote2000cc)
no this block will be all motor,
Old Sep 30, 2002 | 11:43 AM
sgT's Avatar
sgT
will be fine.
Old Oct 1, 2002 | 05:02 AM
pinota's Avatar
Everything is fine with my 82.mm bore setup with stock sleeves so far.
Old Oct 1, 2002 | 07:13 AM
lazyguy's Avatar
Default Re: is it necessary to resleeve the block if running 82mm pistons (pinota)
what kind of power are u putting down pinota?
Old Oct 1, 2002 | 08:47 AM
pinota's Avatar
Didn´t dyno it yet after new rebuilt.
Had 173hp to the wheels with compression problems, becouse of leaks on valves. Serious leak !
I´m probably above 18x.
I´´ll dyno it probably this week.
Old Oct 16, 2002 | 03:45 PM
Rydaddy's Avatar
So you can bore out stock b16 sleeves to 82mm and run all-motor safely?
Old Oct 16, 2002 | 05:26 PM
lazy bum shaughn's Avatar
If you're going to spend the money to resleeve your block to only 82mm, why not send get it resleeved to 84?
Old Oct 17, 2002 | 08:52 PM
lazyguy's Avatar
Default Re: is it necessary to resleeve the block if running 82mm pistons (Breakdancer)
read the post man i dont want to pay to get it resleeved and asked if i can bore it to 82 with out sleeving
Old Oct 18, 2002 | 04:25 AM
pinota's Avatar
Man, i´m running my B18C with a 82.mm bore and it´s
I´m driving my ITR very hard and it´s , i´ve checked last week the cilinder walls and they´re
GT500FTW
Nov 3, 2014 02:32 PM
jceltalentoso
Jan 15, 2012 10:00 PM
slammedbbs
Jun 6, 2011 09:32 AM
tradiuli
Feb 27, 2011 07:44 AM
Beast53568
Aug 5, 2002 11:05 PM
