CD Suspension issues
Old Mar 16, 2011 | 10:08 PM
jdmcrx1's Avatar
Default CD Suspension issues
Hello,
I havent been on here in a while but I currently have a 96 4 door Sedan (accord).
I have a slight problem with the upper control arms. My suspension setup is as Follows:
Hayame FULL coilover setup
Skunk 2 Upper Arms
new urethane bushings front and rear
My problem is that I am having an issue with the Uca's hitting the upper wall of the wheel well. Not where the ball joint is but right in the MIDDLE of the arm. I can see two spot where it is hitting(red paint rubbing off.) The car is pretty low and would like to stay that way but the knocking is driving me crazy and I dont want to do any damage to the Arms.
Is there anybody who has run into this problem???
I hope thats clear if not I will post up a pic of what is hitting.
This is where it's hitting.. Any ideas?
Thanks in advance,
Tony
Old Mar 16, 2011 | 11:10 PM
pjschmitt's Avatar
Default Re: CD Suspension issues
Would taller bump stops make a difference?
Old Mar 17, 2011 | 04:35 AM
nus_dogg's Avatar
No, bump stop won't make a difference.
It shouldnt' hit using the Skunk2 EF UCA. I'd talk to the Hondasociety[dot]com guy cause there's quite a few good guys over there that are running them with no issue and they are pretty damn low with low offset wheels.
Old Mar 17, 2011 | 07:51 AM
jdmcrx1's Avatar
I will post over there and see if anyone else has some ideas. Thanks..
I am welcome to any other ideas too!
Old Mar 17, 2011 | 04:34 PM
Balwin's Avatar
get to hacking and cutting.
Old Mar 17, 2011 | 06:26 PM
jdmcrx1's Avatar
I figured that would be the end result. Dont think i want to resort to that.
Thanks for the input though.
germanturtle
Suspension & Brakes
11
Jan 26, 2013 09:12 PM
tatmark1
Suspension & Brakes
10
Oct 11, 2007 05:30 PM
clarkekent13
Suspension & Brakes
Oct 7, 2005 06:48 AM
hs2000
May 27, 2003 09:29 AM
