Suspension & Brakes Theory, alignment, spring rates....
suspension help
Old Mar 16, 2011 | 09:44 PM
mr_ak's Avatar
Default suspension help
hey i have a question if any1 can answer for me plz i have type r shocks n springs n lca's it came off a 95 honda civic hatchback cx, will it fit on my 99 civic coupe si? also i am swapping out the type r springs for skunk2 springs for a little bit lower ride will this work on my 99 civic coupe si? and also can i use the type r lca's to or will i have to replace them?
Old Mar 16, 2011 | 10:20 PM
98civdx's Avatar
Master Detailer
Default Re: suspension help
The front's will fit.
The rear's will not. You will need "ITR" Spec LCA's. The OEM ones will NOT fit.
The only ones that will work are Function7 ITR spec control arms. They are $300+
Old Mar 16, 2011 | 10:57 PM
JL01's Avatar
Believe he said he has the Type R LCAs as well.
Old Mar 17, 2011 | 12:11 AM
mr_ak's Avatar
i do have the rear type r lca's
Old Mar 17, 2011 | 01:10 AM
98civdx's Avatar
Master Detailer
It's doen't matter if he has them. They won't work!
The only control that will work comes from function7.
The 96-00 lower controls are longer, than the DC control arms. Type R control arms WILL NOT work in his car.
Old Mar 17, 2011 | 01:13 AM
98civdx's Avatar
Master Detailer
Sell them, you can't do anything with them.
Old Mar 17, 2011 | 06:05 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Sell the ITR LCA's, and the ITR springs if you're planning on getting different springs. Or just sell everything if you don't plan on using those shocks with Function7 LCA's for your car.
There are plenty of people out there who would like to buy ITR springs and LCA's. You can get a pretty good bit of money from them I'm sure.
Old Mar 17, 2011 | 09:38 PM
mr_ak's Avatar
hey thx for all the help guys 1 more question if i do use my type r shocks n put skunk2 springs on them can i use blox lca's on the type r shocks or it wont work at all? and if only the function7 lca's work how much would they go for n where can i get it from?
Old Mar 17, 2011 | 10:43 PM
98civdx's Avatar
Master Detailer
Not be rude, but did even read what I posted?
The only company that makes LCA's for 96-00 that are compatable with Type R shocks is funtion7.
Look at the the shock, compared to what's in the car.
You will see the difference quickly.
Old Mar 17, 2011 | 11:33 PM
mr_ak's Avatar
hey sorry i didnt read the post properly n thx for all the help i appreciate it a lot
Old Mar 18, 2011 | 08:59 AM
PreyStayShun's Avatar
Pats right...just to let you know, ITR springs and LCA combo is selling right around $250-$350 right now. Thats a good chunk of change brother!
iheartDc2
Feb 18, 2006 08:02 AM
alfaaay
May 22, 2005 10:18 AM
ForceFed Coupe
Dec 7, 2004 08:45 AM
jpb105079
Jun 1, 2004 10:10 PM
216.226.142.95:27016
Mar 12, 2003 09:02 AM
