Help! my 88 crx dx auto won't restart after I shut it off???
Old Mar 16, 2011 | 08:45 PM
goobous's Avatar
Icon2 Help! my 88 crx dx auto won't restart after I shut it off???
Hi Gang
I am proud to announce I just picked up my wifes first car (twin) an 88 CRX dx Automatic with 75k original miles on it. I have much cleaning, scrubbing and fine tuning to do but it is all there and the ac still works!
It drove 30 miles home just fine, but when I stoped I couldn't get it to crank over at all I tried for 30 min or more, when I came back later it started right up? I drove it home, shut it off and tried to start it again and NOTHING it wouldn't even crank, after letting it sit for a couple hours it started right up again? shut if off right away and tried it immediately again and again NOTHING! I am baffled ? It defies anythig I can think of?
I am sure someone has experienced this Please enlighten me? (before I go mad hahaha)
Thanks in advance?
PS all my brownie points are in danger of disappearing if I can't get it going soon! hahahaha SAVE THE BROWNIE POINTS HAHAHAHAHA!!!!
Old Mar 16, 2011 | 09:09 PM
MarkOlson's Avatar
OG Hot Rodder
Default Re: Help! my 88 crx dx auto won't restart after I shut it off???
My son's CRX had this problem. We fixed it by replacing the ignition switch harness with a junkyard unit.
Old Mar 17, 2011 | 03:19 AM
goobous's Avatar
INTERESTING? Thanks for the input.
Does that just unplug, and snap into the wiring harness?
Has anyone else had this happen with a different solution? I want to cover all the bases! GodBless Brian
Old Mar 17, 2011 | 07:29 AM
AlaskaREX's Avatar
Here is a helpful link that someone posted awhile back covering Honda's notorious main relay and other intermittent starting problems. It is written for the ER but still applicable. Working through it may help you uncover your problem.
http://techauto.tripod.com/index.htm
Old Mar 17, 2011 | 08:30 AM
crx89k20's Avatar
The solders on your main relay have failed or the wires going to them have came loose. You can solder the old one back together, or just buy a new one (that's what I did).
Your car will start when it's cool, but as soon as it gets warm, the relay will fail = no start. I used to have to wait 30 minutes after pumping gas to go anywhere.
Old Mar 17, 2011 | 08:49 AM
4drEF's Avatar
Keyboard Humorist
Had a similar issue with a battery failing.
can you hear the starter >click< when it's failing to start?
Old Mar 20, 2011 | 08:55 AM
goobous's Avatar
Thanks a Ton indeed it was the main relay!
replaced it and we are up and running!!!! now it's time to spit and polish and make it look nice
Thanks
mavrik8511
Classic Hondas
Mar 5, 2017 05:13 PM
goobous
15
Mar 22, 2011 07:10 PM
jaymua
Mar 1, 2010 02:20 PM
