Problems with code 20!!!
Old Mar 16, 2011 | 05:46 PM
jabiboo's Avatar
Icon2 Problems with code 20!!!
Hey everyone I'm workin on a 90 hatchback. I hav swaped the engine with a ZC DOHC engine. I also got a PG7 ECU, now the ECU light flashes 20 times which means its an Electric Load Detector problem. How can I fix this???
Old Mar 16, 2011 | 07:33 PM
HAMOTORSPORTS's Avatar
Default Re: Problems with code 20!!!
Open up the ECU and remove BR1 on the circuit board within your ECU. Problem fixed. The only better option is to install a PM6 that is chipped to run the dohc ZC engine.
Old Mar 16, 2011 | 09:49 PM
jlk16188's Avatar
i dont have any dohc zc experience but i did swap a sohc zc into my crx. I had the same issue before the swap however. I swapped out the whole under hood fuse panel (bc the eld is built in and cannot be removed individually) and the problem went away
Old Apr 28, 2011 | 06:09 PM
betacho's Avatar
What can I remove in a JDM P08's ECU circuit board to get rid of the ELD code 20? I just recently converted it to manual by removing resisters RP17 and RP18.
My engine code is d15b vtec and code 20 is the only error I have to eliminate to turn off my check light. Get the ecu chipped here in my country is quite expensive, so I'm looking for alternative options.
catamanchuk
Apr 12, 2013 07:18 PM
alwaystootall
Mar 2, 2009 08:03 AM
crx5
May 4, 2005 07:31 AM
ek_99_SiR
Feb 21, 2004 02:23 PM
RallySportCivic
26
May 3, 2003 07:40 PM
