Heat
Old Mar 16, 2011 | 12:22 PM
curtie94's Avatar
Default Heat
I just put a new radiator and thermostat in my 1991 Honda Accord. I did NOT have heat before and I still don't. I thought it was my thermostat. The bottom radiator hose is cold all the time, while the top is really hot. I also noticed that the inlet hose to the heater core is hotter then the outlet. I already did a back flush. I Also noticed that when I move the temperature dial from hot to cold my blower picks up. Any Ideas will help.
Old Mar 17, 2011 | 06:02 PM
quickster's Avatar
Default Re: Heat
Sounds like you have a clog somewhere, maybe multiple clogs. try moving the heater control valve switch in the engine compartment. its near the firewall behind the left side of the throttle body
Old Mar 18, 2011 | 10:53 AM
curtie94's Avatar
Default Re: Heat
The switch does move. I also noticed that the warmer it is outside the more heat I get.
Old Mar 18, 2011 | 10:55 AM
quickster's Avatar
Default Re: Heat
does that switch go back and forth when you turn the dial inside your car? if not, then you need to replace that. Its called the Heater Control Valve. Costs about $40 new, or $10 at a junk yard.
Old Mar 18, 2011 | 11:33 AM
curtie94's Avatar
Default Re: Heat
yes it goes back and forth. Before I changed the radiator and thermostat I could squeeze all of the radiator hoses completely together, now they are hard as a rock. After the heat control valve it seems the hoses seem to get colder.
Old Mar 18, 2011 | 01:06 PM
quickster's Avatar
Default Re: Heat
u probably have a clogged heater core. there is a youtube tutorial on how to fix that.
Old Mar 18, 2011 | 02:03 PM
curtie94's Avatar
Default Re: Heat
I already flushed it and nothing came out, but water.
Old Mar 18, 2011 | 06:27 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: Heat
Did you also flush the inlet and outlet?, you may also want to try a strong chemical, something that will eat away gunk. I would recommend liquid Drano or similar. If you don't feel safe with something that strong use bleach, let it soak for awhile.
Old Mar 18, 2011 | 06:33 PM
curtie94's Avatar
Default Re: Heat
How would you flush the inlet and outlet?
Old Mar 18, 2011 | 07:42 PM
Community Builder
Default Re: Heat
http://www.youtube.com/watch?v=dcL_0...feature=fvwrel
DVPDC2
Jan 27, 2013 11:45 AM
marylou
36
Jul 26, 2010 02:41 PM
lee0149
Feb 5, 2009 04:26 PM
bow tie
Aug 23, 2008 10:05 AM
clm
Oct 26, 2006 03:14 PM
