92 integra gsr bogs on when throttle is open
Old Mar 16, 2011 | 08:20 AM
92gsrlord's Avatar
Default 92 integra gsr bogs on when throttle is open
Kk not sure how to word this but here it goes. My car idles like a dream but it bugs at half or full throttle basically as soon as the gas is touched.
Thrings I have done;
New dizzy p, plugs and wires
Test values on the following thing;
Map sensor, OK
Tps sensor but had wierd values closed throttle was 4.9 volts full open throttle 1.8
Tested vacuum presure and it was at 17psi
Compress was 190 across the board
Leak down values are all normal
Disconnect fuel pump and tested volts going to the fuel pump 7.8 V
Timming did not jump a tooth it is bang on
Disconnect ecu and tested with other p61 that I know is working
Any ideas ???
Thanks folks
Old Mar 17, 2011 | 07:22 AM
Mr. Em1's Avatar
Default Re: 92 integra gsr bogs on when throttle is open
That's weird, try and unplug the ecu for at least 5 minutes and then plug it back in and drive. any check engines?
Old Mar 17, 2011 | 07:07 PM
flush_EJ1's Avatar
There should be 12v at the fuel pump. That might be the issue.
Old Mar 17, 2011 | 07:14 PM
night's Avatar
accel slow and if it revs all the way smoothly it is fuel not holding pressure.
rolledthatho
Feb 20, 2011 05:58 AM
si del sol 94
18
Sep 16, 2009 07:39 PM
mcspd704
Jan 5, 2006 11:55 AM
B18C5-EH2
Oct 21, 2003 09:06 AM
