I need to fix my A/C
Old Mar 16, 2011 | 06:19 AM
Bird333's Avatar
Default I need to fix my A/C
Car '96 Accord EX. Ok so I have had a problem with my A/C leaking out for about 3 years. Last year I used the 'super sealer' and it seemed to work but now is seems like the freon has leaked out again. There may be other problems with the system also that I am not aware of. My question is between the dealership and going to another non dealer mechanic to fix this once and for all which do you recommend?
Old Mar 16, 2011 | 10:30 AM
rxbahamut's Avatar
Default Re: I need to fix my A/C
You can get a tool used to detect a leak, or use the dye and a black light to find out what is leaking. From here you can evacuate the system and replace the part, then pull a vacuum on the system and refill it with refrigerant. It should be good to go.
powerlineDC2
Jun 5, 2010 02:14 PM
ReVeNgEd-SoN
Jan 8, 2010 09:54 PM
aceszhigh
Nov 24, 2008 01:31 PM
90accorddx
Audio / Security / Video
Oct 31, 2006 02:20 PM
