h22a NO compression ?
Old Mar 16, 2011 | 02:23 AM
b18c1del's Avatar
Icon2 h22a NO compression ?
interested in buying a jdm h22a longblock w/ NO compression
> Q ? = suggestion on possible causes & is it worth the rebuild
Old Mar 16, 2011 | 04:35 AM
godslayer's Avatar
Default Re: h22a NO compression ?
Is it worth it? How would we know without knowing what the motor looks like, how many miles are supposedly on it, and how much it is being sold for?
Could be any/all of the following:
- No spark plugs (assuming you're just cranking it and not checking with a meter)
- Loose head bolts all around
- Broken/blown head gasket
- Bent/stuck valves
- Cracked/broken head
- Cracked/broken block
- Damaged pistons/rings
If it has ZERO compression across all cylinders, and the current owner can't tell you why, I'd pay no more than $50 for it.
Old Mar 16, 2011 | 06:55 AM
1GPlusSH's Avatar
how much are you willing to put into this motor? it may not even be buildable
Old Mar 16, 2011 | 10:42 PM
b18c1del's Avatar
Icon3 Re: h22a NO compression ?
thanx > priced @ $400 obo & did not state why the prob
so i probably will skip it > thanx again for the reply
Sparksman
44
Jan 9, 2014 12:46 PM
coomplife05
Mar 15, 2012 08:41 PM
coomplife05
Mar 15, 2012 06:00 PM
JBirch_97Prelude
Nov 14, 2008 08:27 PM
Bombino
Apr 15, 2002 01:13 PM
