z6 head and pm6 ecu
Old Mar 15, 2011 | 05:14 PM
wawi0069's Avatar
Default z6 head and pm6 ecu
i just want to know if the pm6 ecu will work on z6 head? thanks!
Old Mar 16, 2011 | 07:34 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: z6 head and pm6 ecu
google... PM6 : 88-91 Civic/CRX SOHC Si
so yes but..what car..what bottom end?
Old Mar 16, 2011 | 08:15 AM
wawi0069's Avatar
i have a 90 civic std with d15b1 engine. i want to put a z6 head but im searching yesterday and from what i read, p26 ecu is better but the problem is its obd1 while my harness is odb0. i think its a hassle to convert obd0 to obd1. what do you think?
Old Mar 16, 2011 | 08:35 AM
I'm not Rick!
you can actualy chip some obd0 ecus. it will work but not perfect.
your changing up compression which would need a custom bin.
you can chip an obd0 ecu and jus ask xenocron.com to make you a map(bin) aka chip to your specs for $30 and send it to you.
plug in the chip and away you go
Old Mar 16, 2011 | 01:55 PM
xenocron's Avatar
It can, here are a few OLD write-ups I did:
http://www.xenocron.com/te.php?page=TEvtec
killerken25
12
Feb 6, 2012 12:04 PM
jdmekrobot
Sep 4, 2006 09:40 AM
vegeta420
Dec 23, 2004 05:16 AM
4door93civic
Jul 21, 2004 12:16 AM
