Crower Cams?
mmmmmmmm prettttty!!!
BTW- i sotle this pic for tihs thread...
https://honda-tech.com/zerothread?id=279779
On Crowers first few batches of DOHC vtec billet cams they had problems with them breaking, supposivly everything is cool now...
I use a set in my ZC, seem to work just fine.
(I only had to weld them back up once... J/K)
Jeff
Jeff
I have a set of 63402's that I ran in my daily driver w/ B16A for a year or so without problems. I was using ITR/Portflow springs and Crower Ti retainers and reved it to 9k almost every day. No problems at all.
I am kind of leery now though after all the breaking stories. I was running them in a 500$ B16A, but I'm building a new B18C with much more $$$$ invested and I really don't want to take a chance.
Anybody want to by a set of 63402's?
I just bought a set of ITR cams for my B16. ITRs in my opinion is the most reliable way to go and they give you plenty of extra power. The only better cams out there would be the TODAs, but are about 3-4 times the price of ITRs. If you can afford it, get a set of JDM CTR cams, they are a little more aggressive, otherwise get the USDM ITR. I've heard '00 USDM ITR cams are the same as the JDM CTR, so you could get a set of those.
Again, type R cams are cheap and reliable. That's why I went that way. Oh, and I got a good deal on a pair too.
There is a set of Type Rs selling right now on ebay, but the guy is asking way too muck, fist bid is at 450 us which is the price of a new JDM CTR kit!
Good luck! Keep us updated!
ITR/CTR cams will give u 5-10 WHP
skunk2 stage1 will give u 15-20 WHP
the toda spec A is a waste-equiv. to tpye R
spec B's are equiv to skunk2 stage 1 in WHP gains.
dunno **** about JUN camslol
The Crower cams broke because of improper installation or improper valvetrain specs. Of all the reported cases of people breaking the Crower cams, nobody claimed to be using only Crower valvesprings...always a combo of something else.
So...if you run Crower's stuff then I don't forsee any problems.
As far as making power goes skunk2 Stage 1 makes awesome numbers in B16s, Stage 2 is actually not as beneficial.
I personaly would buy their no-vtec B18-B20 cams.. they make good power all the way to 8-5K-9k rang.
-but if you have a B16a-B18c I would get skunk or other cams, they don't tend to make as much power though.
* as for cams breaking...... all cams can break...Go in to the ITR form and ask them which cams will not break they will tell you the same thing i'm about to tell you. :::::::get them properly insatalled and tunned.
If you imporperly install Jun3 they will look just like that pix.
I got the 63402 in my 2.0 L B18C6 and got no problems. They make good power, for allday or trackuse.
Maybe i cange them to try the Skunk2 next year, just to see where the difference is, not 'cause they can brake, every cam can brake
Are the todas only better in peak or also in midrange?
