92 Honda Accord shakes only when accelerating
Okay I have a 92 Honda accord with alot of new work done to the front end. it has new struts upper control arms brakes pads calipers sway links front tires torque mount axles wires plugs valve cover gasket wheel bearing on the passengers sid. It only shakes when I am accelerating not in first though. Its a standard. I'm just getting the post out there and hoping I can get some insight was going to check the egr ports and valve
I have changed both 2 weeks ago then I had to replace a passenger side wheel bearing and axle
I am hoping its not that what kind would u recommended if any
I bet you have aftermarket axles. I went through 3 pair from Autozone before I realized it was the axles. They aren't properly balanced and the manual transmissions are sensitive to this. They work perfect for automatics but manuals are more sensitive in my experience.
VolvoDude
Jun 15, 2013 01:20 AM
ReadyToRetire
Sep 11, 2010 10:49 AM
