How do you time a 98 civic?
Old Mar 14, 2011 | 03:47 PM
pityocamptes's Avatar
Default How do you time a 98 civic?
1998 Honda Civic EX
I have commented on here how I hear a slight tapping in the morning, before complete warm up, then it seems to go away. I am wondering if this is timing related as it takes two to three cranks of the key in the ignition to start the vehicle. Timing belt, etc were recently replaced and I wonder if they just marked the crank and cam for belt placement to avoid timing? In any case what cylinder do I time off of? I have one of those timing guns that you need to put inline of the spark wire, I assume this would work. I also assume that there are timing marks on the cover? Thanks again! Any info appreciated.
Old Mar 14, 2011 | 03:56 PM
rednwhiterocket's Avatar
Default Re: How do you time a 98 civic?
I would recommend a hanes manual or equivalent but if mem serves line the arrow's on cams up straight up and down (12 o'clock) and u will have marker that will show tdc (top dead center) on the crank u will have to find this and line this up for timing to b right. Is it a dual or single cam ?
Old Mar 14, 2011 | 03:58 PM
ex i see it d 16 am i right
Old Mar 14, 2011 | 03:59 PM
Originally Posted by rednwhiterocket
I would recommend a hanes manual or equivalent but if mem serves line the arrow's on cams up straight up and down (12 o'clock) and u will have marker that will show tdc (top dead center) u will have to find this and line this up for timing to b right. Is it a dual or single cam ?
Single OHC. I have a Haynes manual, but figured I could get more straight away info here...
Old Mar 14, 2011 | 04:21 PM
Project Dad's Avatar
on a v8 you go off of #1 cylinder with a timing light
Old Mar 14, 2011 | 04:26 PM
V8 in a Honda Civic... alas, I am stuk with a 4 banger...
Old Mar 14, 2011 | 04:31 PM
grumblemarc's Avatar
The Grumpiest
Follow the Haynes manual. Of check the FAQ. I'm sure there are some links there.
Old Mar 14, 2011 | 05:17 PM
just throwing it out there. probably the same for the 4 banger but not positive. nopt going to hurt to try it. what all of 5 mins computer chair to computer chair
Old Mar 14, 2011 | 05:20 PM
No problem. Just joking. I'll have to crack the ole Haynes manual. Damn, did I say I HATE cars with a passion? I think I have worked more on my cars in my life time than number of times getting laid...
At least my vehicles don't expect me to talk to them when I'm done... hahahahahaha...
phil1039
Feb 16, 2014 06:47 PM
UCDags06
22
Feb 12, 2014 04:42 PM
Salsa
Feb 28, 2009 11:31 AM
frank_O
Dec 15, 2005 07:53 PM
