94 accord lx bad power drain
Old Mar 14, 2011 | 03:29 PM
campfire's Avatar
Default 94 accord lx bad power drain
In my 94 lx my battery dies over nite I pulled my amp off looked at my stereo all wired fine looked at my sig ligher pulled it out still does it. I jump started the car pulled the battery off alt ran fine and put the battery back on it charged it then few hours later it dead again its a new battery so Im totally lost. I checked the fuses all are new Inside the car. What am I missing
Old Mar 14, 2011 | 06:42 PM
chikin pickle's Avatar
Default Re: 94 accord lx bad power drain
Check your car for shorts.
Grab a volt meter, set it to check for continuity and look for continuity between the positive cables and the chassis (ground).
Try pulling the battery fuse as well and see if the solves the problem. This will determine whether your short is in the battery cables or somewhere in the vehicles electrical system.
CgClam
Apr 21, 2019 06:13 PM
wood181
Apr 15, 2008 06:59 PM
skiracer8148
Jan 4, 2006 09:00 AM
