Ooops, accidentally snapped fuel rail bolt, now what?
Old Sep 26, 2002 | 04:45 PM
Quik Chris's Avatar
Default Ooops, accidentally snapped fuel rail bolt, now what?
Alright, My fuel rail has been bored out to fit Mustang Injectors. Everything was cool, unitl today I opted to get the 42# (441cc) injectors to replace the 30# (315cc)ones I've been using. Well the o-rings fit really tight in the fuel rail, so the best way to get them all the way in is bolt the fuel rail to the intake manifold. Well the bolt on the drivers side snapped in my JG Victor X manifold. Now what do I do?
Old Sep 26, 2002 | 04:54 PM
ScrapinSi's Avatar
Default Re: Ooops, accidentally snapped fuel rail bolt, now what? (Midori Shinkansen)
is the bolt part of the JG manifold? or can it be backed out? if it can, go to a junkyard and find another bolt... my friend did the same thing with his STR Fuel rail and Venom Intake manifold...
Old Sep 26, 2002 | 06:11 PM
Quik Chris's Avatar
Default Re: Ooops, accidentally snapped fuel rail bolt, now what? (ScrapinSi)
I have a whole garage full of Honda bolts, I just need it out of the manifold so I can make sure the injectors seal ok. Because right now it's running like **** like that.
Old Sep 26, 2002 | 06:14 PM
ScrapinSi's Avatar
grab it really tight with a pair of vice grips and back it out...
Old Sep 27, 2002 | 12:37 AM
Quik Chris's Avatar
It's broken off below the deck height of the hole for the bolt. I found a way, you can buy crapsman kits from sears designed to get the bolt out.
Old Sep 27, 2002 | 08:08 AM
Tweakmeister's Avatar
be careful with those they are brittle.
Old Sep 27, 2002 | 08:16 AM
skunked's Avatar
Default Re: Ooops, accidentally snapped fuel rail bolt, now what? (Tweakmeister)
go to the hardware store and get a "easy out". They are litle tapered bits with a reverse thread. On the package it will say what size drill bit to buy with the easy out. Then you have to drill a hole in the broken part of the bolt and then screw the easy out into the whole and back that bastard right out. I have been in the same situation, but with a head bolt and it was very easy to do.
Good Luck.
Old Sep 27, 2002 | 10:28 AM
sieger's Avatar
Default Re: Ooops, accidentally snapped fuel rail bolt, now what? (skunked)
They are also know as extractors. Easy easy.
Old Sep 27, 2002 | 12:22 PM
Quik Chris's Avatar
Default Re: Ooops, accidentally snapped fuel rail bolt, now what? (sieger)
Cool thanks guys.
Old Sep 27, 2002 | 12:43 PM
94gsr's Avatar
For future reference, don't install injectors that way. That's a good, easy way to **** up one or more of the o-rings. Clean the o-ring seats & the o-rings themselves, then lube them with some fuel, or whatever's handy. Make sure that they are securely in place before you bolt the rail down.
Old Sep 27, 2002 | 08:21 PM
Farnsrocket's Avatar
Default Re: Ooops, accidentally snapped fuel rail bolt, now what? (94gsr)
you might want to use the correct torque spec also
Old Sep 27, 2002 | 09:04 PM
Quik Chris's Avatar
Default Re: Ooops, accidentally snapped fuel rail bolt, now what? (Farnsrocket)
Thanks dude. Oh, you might want to know the situation first too. I use Mustang injectors, they fit very tightly in my bored out fuel rail. Usually you want the fuel rail to be touching the Imanifold before you even start to worry about toruqe. Easy out didn't work, gonna have to drill it out and helicoil it. Thanks for the suggestion though, I would have NEVER though of that.
lilkim0121
Mar 17, 2022 06:34 AM
Cap'N Chronic
Apr 6, 2011 07:27 AM
98civtec
May 14, 2009 05:47 AM
h22silvia
Mar 27, 2007 01:45 PM
