Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help! 2002 Civic EX intermittenly won't start--cranks
Old Mar 14, 2011 | 10:23 AM
drake24's Avatar
Default Help! 2002 Civic EX intermittenly won't start--cranks
Hi,
I have a 2002 Civic EX automatic with 98K miles. All stock parts. Last year when it got really cold (live in Colorado) it would not start. This happened about twice. It cranks but won't turn over. This year it started happening more frequently and even when the weather is nice. Some days it starts, others it just cranks. The battery is less than a year old. All spark plugs have been replaced within last month. Just replaced Fuel Relay as well but problem remains. Input and suggestions are appreciated! THANKS!
Mike
Old Mar 14, 2011 | 10:52 AM
husyk's Avatar
Default Re: Help! 2002 Civic EX intermittenly won't start--cranks
Try starting it with a jump start kit or jumper cables, if starts right up without issue it may be the alternator. Possibility started is on its way out.
Old Mar 14, 2011 | 03:45 PM
rednwhiterocket's Avatar
I would check the distributer weakest part of honda moter
Old Mar 14, 2011 | 03:47 PM
sorry dude didn,t read whole post start moter let idel then take off neg battery cable if car dies alt shot good luck man
Old Mar 14, 2011 | 05:40 PM
drake24's Avatar
will try that. thanks for the suggestions. Will report back.
Old Mar 14, 2011 | 11:17 PM
It Wasn't Me's Avatar
These cars don't have distributors.
Old Mar 14, 2011 | 11:21 PM
Originally Posted by drake24
Hi,
Mike
Symptom:
Engine will not start. (MIL works, no DTC's set)
- Test the battery.
- Test the starter.
- Check the fuel pressure.
- Troubleshoot the fuel pump circuit.
Being that it's an intermittent problem, that makes finding the problem that much more difficult. Sounds like it's either an intermittent loose connection, or a fuel feeding issue.
Good luck with it.
Old Mar 16, 2011 | 12:27 PM
drake24's Avatar
civic not starting last few days despite weather in 70s. (same issue, crank no start). Tried Jumping it too to see if it would help....did the same thing. Crank but no turnover. Any other ideas?
Old Mar 16, 2011 | 07:34 PM
Did you check any of the things I listed in post #7?
- Test the battery.
- Test the starter.
What about the three essentials for an engine to run?
Air
Fuel
Spark
Which one is missing?
You're going to have to figure that out. This isn't something we can do for you over the internet.
Old Mar 18, 2011 | 04:18 PM
back2boostin's Avatar
Originally Posted by It Wasn't Me
Symptom:
- Test the battery.
- Test the starter.
Good luck with it.
When you are trying to start the car look to c if the key light is on off or flashing on the dash, try a differant key, If its turning over and not starting its not your battery, all that does is crank to motor and feed electric to the system.....just to stsrt it after that the alt kicks in... DO NOT REMOVE THE BATT CABLE WHILE THE CAR IS RUNNING, IT CAN CAUSE A SPIKE AND BLOW YOUR ALT... when you can get it started go to an auto zone or something like that if you have 1 they will check it for free....
Again as was stated.. theres a lot to try to trouble shoot and again good luck
Old Mar 25, 2011 | 01:10 PM
drake24's Avatar
So, took it into the repair shop and they figured out the problem.
About 7 months ago I lost the keys. I had new keys made. I then found the old key. The intermittent starting issue was tied to the keys. When I used the old one, it wouldn't start, the new one, it did. That was the issue.
Old Mar 25, 2011 | 01:40 PM
Ah-ha! You probably should have mentioned that in your original post. Or mentioned that the "little green key light" in your cluster was flashing each time your car refused to start. That's the immobilizer indicator. It would have saved you some funds and guesswork.
Oh well. At least you got it figured out!
Old Mar 25, 2011 | 02:39 PM
drake24's Avatar
I had completely forgotten about it. And there were so many lights that came on I didn't notice the green one. oh well, at least its fixed....I take back the bad things I said about the Honda.
Old Oct 5, 2015 | 04:12 PM
oneosufan's Avatar
I know that this is an old post but I am having the same issue and have read a lot of posts about this. Lets start with what I have done up to this point.
I have changed the following
Complete distributor
Spark plugs and wires
Fuel Filter
Main Relay
Car is a 2003 Honda Civic EX with 200k miles
After replacing the above list of parts the car ran fine for about a week and started every time. Now it is intermittent. It will crank but no start and only has this issue after the car has ran for a short distance (less than 10 miles) and sits for less than 30 minutes before trying to start it back up.
Old Oct 7, 2015 | 03:15 PM
tamboo's Avatar
10 Year Member
could be a bad engine coolant temp sensor.
Starting Problems
Old Oct 7, 2015 | 03:42 PM
oneosufan's Avatar
Changed out the fuel pressure regulator and the air intake sensor last night. Had no issues today so hope that was the fix. I believe it was the regulator but we will see. Thanks for responding.
Old Dec 2, 2016 | 12:09 PM
tonyramirez's Avatar
I have some issues with my honda 2002 civic,I just recently replaced the motor and it started up fine but when I turned it off and put a new battery on and added antifreeze it wouldn't start back up.i just put new spark plugs new battery but it still won't start.the green key light flashes 5 times after I turn it take the key out..but I was told that means the immobilizer is working..need help guys
Marla Lee
Honda Civic (2006 - 2015)
Feb 25, 2017 09:35 PM
Tsmall
Apr 23, 2015 08:08 AM
Sarah Blattel
Oct 10, 2013 05:29 PM
csckwade
Dec 30, 2012 05:10 PM
civic_976
Oct 21, 2004 06:45 PM
