Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Tranny slipping??????
Old Mar 13, 2011 | 08:03 PM
si_motor_spt's Avatar
Default Tranny slipping??????
Hey all, well im workn on my sisters 04 2 dr civic lx automatic, when its cold it goes into gear and drives fine but after driving some miles (10+) or when its really hot the car seems to rev up even in gear.......What i noticed thou is that when im parked(after its warmed up and starts acting up) if i try to change gears(D4,D3,2,N,R,P) it seems to jus be in neutral like it dosent want to change gears.......would a simple flush and additive help?
Old Mar 13, 2011 | 09:45 PM
drzxc1usive's Avatar
Default Re: Tranny slipping??????
Dont ever use flush... is the tranny leaking? does it have enough fluid? u might have burnt a solenoid or clutch in the tranny
Old Mar 15, 2011 | 07:06 PM
No my brother in law didnt use any flush, he put some sort of atf (not Honda ATF) so he drained it and refilled it Honda ATF but i was wondering if i were to get like around 9 qts and jus drain, refill, drive around a little, and repeat(drain, refill,etc) would that help, or can i jus replace one of the solenoids.....
Old Mar 15, 2011 | 07:11 PM
It Wasn't Me's Avatar
There are a few different solenoids that can be replaced, but you'll need to determine which one is faulty... and that can be a headache.
Out of curiosity, how many miles are on the car / transmission?
Old Mar 17, 2011 | 08:13 PM
theirs around 157,XXX miles, it was driving fine until he decided to "fill" the trans because he checked it when it was cold, assuming it was low(i think ur suppose to check it when the engine is running at operating temp) How many solenoids are their? how would i be able to check them?
Old Mar 17, 2011 | 08:41 PM
cmacias2001's Avatar
there are 3, 2 on the front right of the trans, and another under the thermostat housing...sounds like your clutches just died....i experienced the same problem with my last transmission, even with honda atf.
Old Mar 18, 2011 | 12:06 AM
Indeed, you are supposed to check it while the engine is at operating temperature. Basically, you drive it around, park it on level ground, turn the ignition off, and check the fluid level within a minute or two (90 seconds or less, really) after turning it off.
What kind of ATF did he put in, and how much did he add? You might consider a drain-and-refill. (2.9 quarts)
Skimming through, I see 5. (Three different parts, but a total of five solenoids.) Two shift solenoids, two clutch pressure control solenoids, and a torque converter clutch solenoid.
As far as troubleshooting, you'll need to either buy a manual (Helm's is highly recommended) or have a transmission specialist check it out. It'd likely be a lot less expensive to buy the manual, plus you can always use it for other issues that may arise in the future.
Old Mar 21, 2011 | 04:03 PM
Thanks camcias and it wasnt me.....i'll try to get a helms manual asap....
Old Mar 21, 2011 | 08:06 PM
No problem!
Please let us know what you find and how you fixed it. Updates are very appreciated!
Old Mar 24, 2011 | 09:02 PM
partsme's Avatar
on 7th gens, usually the linear silenoid goes bad. Best to buy it from the dealer. Ive changed over 5 of them in the past year. Its pretty common if it sort of slipping. Should do the trick.
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
crucial-vtec
Nov 20, 2005 02:23 PM
tdgcgpgsr
Jul 14, 2005 12:58 PM
chahsiubow
Jun 29, 2004 08:33 PM
EleanoR
Dec 13, 2001 07:54 AM
