AEM Series 2 base cal
Looking for an AEM (10-6040)series2 base cal for a 94GSR. Converting from series one is hit or miss.. mostly miss.
Or any good info where i might be able to locate one to work with.
With the conversion script in the latest software it does a pretty good job at converting it. Although you can start with the supplied base cal and work from there. You can also use the supplied base cal. Copy over your fuel table, start tables, ignition and make sure your micro sec per bit is the same.
xxjonxx4
Engine Management and Tuning
Sep 25, 2012 03:36 PM
