Suspension & Brakes Theory, alignment, spring rates....
Spoon Caliper Twin Block Setup
Old Mar 13, 2011 | 04:27 PM
nursographer's Avatar
Default Spoon Caliper Twin Block Setup
I need help guys on my Spoon Caliper setup. Here's what I have
1. Spoon Caliper Twin Block
2. GSR DC2 Front and Rear Disc Brakes
3. 15" SW388 4x100
4. car is a 96 honda civic CX hatch
My question is, will the caliper fit directly to the dc2 front brakes? If not, what do I need to buy in order to fit it WITHOUT modifying something especially the calipers. I don't wanna start shaving a bnew 1500++ caliper and it should clear a 15" sw388 rims. I was told that I need to buy the $650 11" FastBrake rotor but I was wondering if there are other rotors I could buy as an alternative to it without modifying the caliper. I just wanna do some research first before I buy the rotors. I would appreciate inputs of those who already did the same setup.
***Please don't reply on this thread saying that I shouldn't have gotten the Spoon Calipers and they are overrated and all that stuff. That's what I want and no one can change my mind. Period. Please stay on topic as always.
Old Mar 14, 2011 | 07:00 PM
BlueIntegraBoy's Avatar
Default Re: Spoon Caliper Twin Block Setup
Here, I did the research for you on Google...
You need 92-96 Prelude VTEC 282mm rotors redrilled to 4x100 and 3mm spacers between hub and rotor.
You'll need spacer to run the SW388 according to this thread...
http://forums.nwp4life.com/zerothread?id=11220
Old Mar 17, 2011 | 05:06 PM
scook179351's Avatar
Go to autozone and order 89-91 VW Corrado front rotors. They are 11" 4 x 100 bolt pattern. Not sure about needing the spacers then though.
Old Mar 18, 2011 | 09:32 AM
PreyStayShun's Avatar
I ran accross a thread in the DC2 Brake section less than a week ago where someone is using the stock rotor from the base Mini Cooper...needs absolutely NO modification apparently. They're also lighter and cheaper then the re-drilled prelude rotor.
I currently use the corrado rotor as noted above, there was no need for spacers..but the fit wasn't exact so I'm running w/the Mini cooper solution next time around.
EDIT:
Good 11" Rotor Info...1/2 way down page 3:
https://honda-tech.com/forums/showth...=734560&page=5
Old Nov 23, 2011 | 12:15 AM
HONDA RR's Avatar
nice info.
Drew17th
Suspension & Brakes
13
Aug 30, 2009 07:13 AM
GOOCH-JDM-ITR
Oct 30, 2008 09:38 PM
honda head
16
Jun 27, 2007 08:34 AM
Dveloped
Oct 27, 2003 03:40 PM
eviltwin
Aug 21, 2002 08:09 AM
