91 civic si headlights/dashlights etc. not working!
Old Mar 12, 2011 | 11:15 PM
hatchet_honda's Avatar
Default 91 civic si headlights/dashlights etc. not working!
i have a 91 civic si. stock headlights and all wiring is factory and not hacked at all. im having a problem with my headlights/dashlights not turning on. it started happening about a month or so ago. only a few times but lately its been every single time i try to turn on the lights. i dont think its the switch it seems to be a ground issue maybe. once i was leaving work and they wouldnt work but when i opened my door and shut it they came on. also if i drive for a bit sometimes theyll come on if i hit a bump. where are some grounds i should look for?
Old Mar 13, 2011 | 10:22 PM
Default Re: 91 civic si headlights/dashlights etc. not working!
bump! i kinda need to drive at night
Old Mar 14, 2011 | 01:19 AM
HAfinatic's Avatar
double check fuses first just to see if one is loose. check you battery terminals and make sure there all tight. double check all bulbs in your car as well. its one circuit so if one bulb is loose it could cause the issue. try those first and c what happens
Old Mar 14, 2011 | 01:20 AM
HAfinatic's Avatar
do your turn signals and brake lights work consistantly?
Old Mar 14, 2011 | 06:43 AM
turn signals..flashers..brake lights..dome light..all work. just no dash lights or headlights/parking lights. car starts and drives fine with no other electrical issues. started happening sometimes then last few days it got to where theyd come on randomly after i drove a lil. now nothing
Old Mar 14, 2011 | 06:45 AM
these arent xmas lights. not sure how a bulb loose would cause ALL the lights to go out
Old Mar 14, 2011 | 08:52 AM
fuses are good. diff headlight switch didnt fix it. i hate electrical
Old Mar 15, 2011 | 07:50 PM
one wire on the back of the headlight switch plug has power. i jumped that wire to the wire that goes to the dash lights and they came on
Old Oct 29, 2012 | 03:50 PM
Typ2nuk's Avatar
just for the record, what color were those wires?
Old Mar 19, 2014 | 04:20 PM
DominosPizzaKid's Avatar
im going with dimmer switch
hatchet_honda
11
Feb 13, 2011 07:13 PM
confuseid
Aug 5, 2007 11:53 AM
PieEyedPiper
Dec 2, 2005 11:08 AM
klomast3r
Sep 6, 2005 01:52 PM
EF_ST@TUS
Aug 9, 2005 08:31 PM
