Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car won't start
Old Mar 12, 2011 | 07:13 PM
nsteve's Avatar
Default Car won't start
After i disconnect and reconnect the battery i cant get my Honda Civic 2005 to start. It seems like maybe someone pulled on the handle to many times and it activated and it killed the start switch on the car and its just blinking the lights and wont turn on anymore even i entered the radio code on the radio system.
Old Mar 12, 2011 | 10:03 PM
It Wasn't Me's Avatar
Default Re: Car won't start
Is the battery any good?
And what does ..
.. mean? I don't understand what you're trying to say here.
Anyway, test the battery to make sure it's even good.
Old Mar 13, 2011 | 08:58 AM
nsteve's Avatar
Yes the battery is good i already checked. Someone told me because i disconnected the battery so the anti theft system was activated and it killed the start switch on the car. They told me enter the radio code to deactivate anti theft system and i did but the car is still don't start.
Old Mar 14, 2011 | 11:34 PM
Does the car turn over? Or is it completely unresponsive when you turn the key?
What are the cluster indicators doing? Specifically the Immobilizer indicator? Does it keep flashing?
Have you tried resetting the ECU?
Checked the fuel pump relay?
Can you hear the fuel pump activate when you turn the ignition to the ON position?
Even if the radio was asking for the code, your car would still run without it.
big.turbo.daddy
May 5, 2014 01:32 PM
mrxkvn
Acura TL, RL & ZDX
Jul 30, 2006 04:52 AM
macadoo
Acura TL, RL & ZDX
Jun 24, 2006 11:07 AM
badazzaccrd
May 29, 2004 10:05 PM
