Obd0 to obd1 engine harness
Old Mar 12, 2011 | 03:27 PM
jkm211's Avatar
Default Obd0 to obd1 engine harness
Ok, currently building my hatch. Putting in a d16y8. Ok, I bought a shell, shell came with a obd0 harness, that was butchered by the PO. Well, that said, I have a obd1 harness laying around, I plan I using it. That said, if i were to use it, it won't match up with the bay harness, so what I am asking, does anyone have/know where I can find a pin layout so I can depin the obd1 plugs and put in my obd0 ends from the jacked up harness. So if you can help let me know, if you can't and tell me to search I don't give two craps what you have to say, i did search on here and google, and all i can find is I just need a dizzy converter and well that isn't the case, because three plugs don't go into two. So please and thank you.
Old Mar 12, 2011 | 05:13 PM
crx_si-r's Avatar
Default Re: Obd0 to obd1 engine harness
pm me i can build you a complete harness.
Old Mar 13, 2011 | 05:41 AM
jkm211's Avatar
No offEnse but I really don't want one made. I would really like to do it myself. And based off of the posts of hrs I have read you know how to do it. Now if you could just tell me where I can find the same wiring diagram you did then that would be great.
Old Mar 13, 2011 | 12:16 PM
crx_si-r's Avatar
Hours n hours of searching at first, when I started making them. Use google. All of my personal diagrams that made/use are not online. I let 1 member use 1 and now it's all over the Internet. So all my stuff that I made are only on my comp and sketch book.
Just keep searching and you will find what you need.
95civic59
16
Jan 9, 2015 10:30 AM
lejeaune
Apr 21, 2010 09:31 AM
ozrednsx
Dec 13, 2007 10:55 AM
1BADEGDC2
May 12, 2007 07:43 PM
