Noisy exhaust Valvetrain b18b
Just replaced TB and WP on my b18b and adjusted the valve lash.
Everything is in spec and car runs smooth but I am getting a lot of tapping noise from the exhaust valves (alsmost like a slap). Intake side is perfect.
Also, when I was adjusting the exhaust side, regardless of the lash, the rocker arm can be wiggled from side to side much more than the intake side. I am guessing this may be the culprit; however, not really sure how to address it?
Should the pivot bolts be changed? or adjustment screw?
car has 130K
http://www.hondaautomotiveparts.com/...E+-+ROCKER+ARM
car has 130K
not my vid, but it shows what I am talking about
http://www.youtube.com/watch?v=0puqw...eature=related
I just did a valve adjustment on my lsv with type r cams, to retainer and dual spring, itr pistons. I adJust to
Intake 0.006
Exhaust 0.007
My problem is similar to yours it's tapping from the exhaust side. I will also redo the adjustment see if that works.
Intake 0.006
Exhaust 0.007
I have a friend with the same problem on his EP3, when adjusting his lash I noticed one of the exhaust valves having a loose something ( really hard to see the back side of a K series in that car) it seemed like a retainer or "base" of the spring where I inserted the feeler guage to take measurment.
