Need help. Must drive today. Axle wont go in
Old Mar 12, 2011 | 10:54 AM
Tims Toy 500's Avatar
Default Need help. Must drive today. Axle wont go in
I have never had this happen before. I have had plenty of axles not wanting to come out, but this time the driver's side axle does not want to go in. It's not a seal thing because I have not gotten to the seal yet. However, it must be seated to some degree because when I turn it the other axle turns the opposite direction. Any thoughts as to what may be blocking it? Comments are greatly appreciated.
Old Mar 12, 2011 | 11:28 AM
mruneek's Avatar
Default Re: Need help. Must drive today. Axle wont go in
when u turn one the other SHOULD turn the opposite way...
is it not going in the tranny or the knuckle
Old Mar 12, 2011 | 11:31 AM
Ok so with some brute strength and awkwardness, I got it in. But this confuses me... In the process the other side popped out. What the??? Short of begging here, I could use some good info. Thanks.
Old Mar 12, 2011 | 11:34 AM
jdmboyef9's Avatar
New axle or original axle? More info is needed. Help us help you
Old Mar 12, 2011 | 11:36 AM
jdmboyef9's Avatar
Why was the axle out, where did you get it, what year and model do you have vs what one did you order? Are you sure it has the correct spline count/diameter, correct axle side? Any pics of the axle in question?
Old Mar 12, 2011 | 11:42 AM
AAAH! The drama continues. So I ripped out the driver’s side axle and got the passenger side back in. I’m confident it’s seated properly cause I heard/felt “snap” of the axles c-clip. Now I’m back to square one… the driver’s side won’t go in. I don’t feel like repeating this cycle again… :-)
Here are some facts:
Stock D15 with L3 cable trany.
Trany was out for clutch job.
Same old stock axles going back in.
Old Mar 12, 2011 | 12:02 PM
I'm sure these are pictures of nothing... But maybe someone will see something I don’t.
ralphieg
Oct 2, 2012 06:36 PM
stockb18c
Transmission & Drivetrain
Apr 5, 2009 07:50 PM
wu tang
14
Dec 17, 2007 09:23 AM
ill phil
May 15, 2003 06:27 PM
