91 accord oil leak
Old Mar 12, 2011 | 09:14 AM
brenton01's Avatar
Icon2 91 accord oil leak
im getting oil filling up the pockets right above the exhaust manifold right in front of the engine... the oil isnt comming from the valve cover tho ... i just started it today and noticed, right at the seam of the exhaust manifold gasket, there is some bubbles of air and oil comming from it... im concerned its a cracked head can i get some advice if pics would help i can post.
Old Mar 12, 2011 | 09:29 AM
poorman212's Avatar
Default Re: 91 accord oil leak
Yes, pic's would help, at least for me....has something else happened to make you think it is a cracked head.
Old Mar 12, 2011 | 10:32 AM
brenton01's Avatar
no nothing else .. no smoke from tailpipe just well a lil bit its an old car .. few days ago i drove maybe 2 miles when i stopped a **** load of smoke came from under the hood and there was a decent amount of oil right above the exhaust ... there is some coming from valve cover but not enough to say thats the only problem. its realy wierd its seems to be comming up from under ya know? it looks like its coming from the exhaust manifold gasket not under but on top filling up those little pockets/joints with a pool of oil but that sounds impossible right? do u have an email i cant post pics on this site
Old Mar 12, 2011 | 01:29 PM
holmesnmanny's Avatar
Just upload to a free pic site then post the link.
Old Mar 12, 2011 | 06:23 PM
chikin pickle's Avatar
Your valve cover is the only place in the area that contains engine oil.
If it's not coming out of the gasket and your head isn't cracked (which you would probably know) then check the spark plug tubes, it could fill them up and the VC painted black doesn't like showing oil leak paths. Also, check the rubber grommets under the bolts/nuts. These can also leak oil if the crack or age too much.
Old Mar 13, 2011 | 09:03 AM
brenton01's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 13, 2011 | 07:17 PM
Your valve cover is leaking. It's seeping out from the gasket under crankcase pressure. Change it.
MHaz1701
Jan 25, 2018 07:39 PM
CBL9
Oct 25, 2010 05:29 PM
JDMgunmetalCRX
Jul 8, 2009 12:49 AM
wengejor
Feb 10, 2009 10:12 AM
AccordEX1991
Dec 16, 2005 05:45 PM
