ECU Fail.. PAA-L74 Swap Question
Old Mar 12, 2011 | 04:25 AM
VTXkruser's Avatar
Icon2 ECU Fail.. PAA-L74 Swap Question
I have a 2000 Accord 2D auto. The ECU took a crap and I purchased a replacement but need immobilizer code. Can I unsolder the IMMO from my old ECU and install in into the doner ECU? Has anyone ver done this? I dont see why it would not work but dont want to take a chance of trashing the doner. Both ECU's are the same part number.
Old Mar 12, 2011 | 06:35 AM
InvaderTrax's Avatar
Default Re: ECU Fail.. PAA-L74 Swap Question
I don't think you can, but I've seen J35 ECU's with the IMMO desoldered and it works just fine
Old Mar 12, 2011 | 06:11 PM
chikin pickle's Avatar
Take it to the dealer. They can cut IMMO keys. The ECU has a serial number, which thanks to theft prevention practice, corresponds to a VIN, which they have the code for. Bring your receipt for the ECU and I'm sure they will be able to program your keys accordingly. Unless it's stolen.
Old Mar 13, 2011 | 05:18 AM
VTXkruser's Avatar
The key is not the problem. Even if I have the dealer cut a key they would still need to reflash the ECU for install into my Accord. I have the keys and the IMMO code is stored inside the Failed ECU. The replacement ECU from a doner vehicle has the old vehicles info stored on it. I want to know if I can unsolder and swap the IMMO circuit board?
Old Mar 13, 2011 | 05:20 AM
VTXkruser's Avatar
From what I understand this will throw a CEL. I cant pass emmissions with CEL.
Old Mar 13, 2011 | 08:07 AM
HAMOTORSPORTS's Avatar
Why don't you just tow your car to a dealer and have it programmed? Sure will save a lot of headaches...
mcole1973
Mar 16, 2011 06:06 PM
reenot
Jan 18, 2011 06:12 PM
zenon8890
Mar 12, 2009 02:21 PM
reyrey2006
Sep 21, 2008 11:19 AM
darkstarmeyers
Apr 21, 2005 07:47 PM
