90 prelude s, axle nut will not budge!
Old Mar 11, 2011 | 08:02 PM
McGruber's Avatar
Default 90 prelude s, axle nut will not budge!
So I'm replacing the cv half shafts on my friends 90 prelude s cause both boots are completely torn, the car is a mess. Anyway I go to remove the axel nut with the car on the ground using my breaker bar and 5ft pipe for leverage and my breaker bar brakes lol. I buy a new one and brake that the exact same way. I'm stumped, I've done this tons of times on other hondas and never had a problem. Is there a trick on ludes? Also I might add that I soaked it in pb blaster first and unstaked the axel nut tab. Any help would be much appreciated, thanks.
Old Mar 12, 2011 | 04:22 AM
gc8dc95's Avatar
Default Re: 90 prelude s, axle nut will not budge!
No, theres no trick on ludes. Try heating it up with a torch, or if you have access to an impact. Also, you can try hitting on the breaker bar with a hammer a few times. It may just be the original axle and has 20yrs of corrosion holding it in there.
Old Mar 13, 2011 | 09:34 PM
McGruber's Avatar
Ya, I'm prabably gonna try using a really powerful impact wrench when I have time at the shop. And ya I'm pretty sure it's the original axel nut from the car lol yikes! Thanks for the suggestions.
Old Mar 14, 2011 | 07:03 PM
Don Jefe's Avatar
I dunno man, I thought I'd never get them off my lude either. Went to the scrap yard and got me a 1/4 inch thick, 5ft long steel pipe with a breaker bar. Oh, plus half a can of pb blaster lol.
Old Mar 15, 2011 | 04:48 AM
1GPlusSH's Avatar
happened to me, too. try tightening it just a little before you go to loosen it. you may have years of that nut pressing against those threads. you may not be able to loosen it until you tighten it just a little(you don't have to turn it more than 1/8 of a turn).
Old Mar 15, 2011 | 06:09 AM
accordmatt's Avatar
^ what he said then hit with a lil pb blaster and wipe excess off so u can get a grip on it then try taking it off if no luck still pb and let it sit for awhile and spray a few times and let sit. next thing would be a good impact and just hold it there for a min until it breaks loose
90Rexx
51
Oct 26, 2010 12:55 AM
brodyl05
Suspension & Brakes
73
Jun 27, 2007 07:38 AM
italstallion
Apr 20, 2006 11:10 PM
rasta420
24
Oct 11, 2004 03:09 PM
20lb.teg
Oct 8, 2002 09:13 PM
