Suspension & Brakes Theory, alignment, spring rates....
possibly a bad caliper?
Old Mar 11, 2011 | 04:03 PM
Doffo's Avatar
Default possibly a bad caliper?
Hello,
When I installed new rotors and pads on my Honda Civic, something didnt seem right. On the passenger side would spin without any friction/tension from the brake pads or caliper... But when you go to do it on the drivers side and spin it by hand, it would go about 3/4 of a turn, then everything would tense up and be hard to turn at all. I really had to keep turning on the extended wheel studs i installed for it to get out of the lock...... Is there chance that the caliper is getting "stuck" so to say on a side?
Thanks again. Any help on this is appreciated. I will also end up going back and take apart the caliper if advised to to lube up the parts.
Old Mar 12, 2011 | 03:40 PM
barryboy1111's Avatar
Default Re: possibly a bad caliper?
Take it apart again and make sure everything is where its supposed to be. Make sure you grease the calipar slides and also have brake stuff on the bake of the pads.
Old Mar 14, 2011 | 07:48 PM
Doffo's Avatar
Ill take a look once I go to do my rear disc conversion. I know it went back together right, just wasnt aware if one of the sides was sticking.
Old Mar 15, 2011 | 05:52 AM
BDogggUT34's Avatar
Is it sticking in the front or rear? I just redid everything on mine as well, passenger rear was completely siezed, so Advanced Auto for $43 new caliper. The drivers side I took apart, re-lubed and put back on. However, it seems to have trouble releasing completely after the emergency brake is engaged. I can pull it fully back by hand. May be a worn out spring not allowing it to fully retract, or could be the inside cam just rusting out. I'm gonna spend another $43 and get a new caliper for this side as well.
Check that though and if there is any doubt, just spend some money and replace it. Its not all that much, and might I add, an important part to your car :-)
Old Mar 15, 2011 | 02:56 PM
Spitfire8o5's Avatar
when i did my GSR F/R brakes on my EG it felt like that too even though i got new pads and resurfaced the rotors.. what i ended up doing is putting them through hell (get them really really hot) and parked it in gear overnight (leaving the e-brake up after you got your brakes really hot can warp your new set up) and the next day they felt awesome..
Old Mar 16, 2011 | 07:28 AM
Doffo's Avatar
@ BDoggUT34
You know, someone told me the same thing that you can get a new caliper for $43.... I can't find them anywhere!
@Spitfire8o5
You know, that sounds like a plan.... I probably shouldnt do that where i go for a long drive,then put on my ebrake.. I will let you know what comes of it once I use the gear to park it instead. Thanks.
Old Mar 17, 2011 | 07:47 AM
BDogggUT34's Avatar
[QUOTE=Doffo;44875689]@ BDoggUT34
QUOTE]
I'm in Ohio and went to Advanced Auto Parts. Check your local parts stores and find out. They also may be giving you a price that includes the core. Its actually like $73 but i gave them my bad one and you get that core price back which was $30.
Old Mar 17, 2011 | 10:17 AM
It did me wonders man, and just take some bricks to out in front and behind one of your rear wheels if you don't want to leave the car in gear.. And hope it works for you man
born2lose
11
Jun 17, 2012 06:27 PM
95halx
Apr 1, 2011 05:11 PM
KyleVA
Nov 24, 2009 09:39 AM
MachAF
Suspension & Brakes
Sep 26, 2009 10:02 AM
P@@RB@Y
Mar 5, 2006 06:06 PM
