holding my steering wheel 90 degrees
Old Sep 26, 2002 | 02:24 PM
djay86's Avatar
Default holding my steering wheel 90 degrees
Well, my alignment was pretty bad before my wreck.. i was holding my wheel at about 40 degrees.. after the front end wreck, its more like 90 degrees...
While my car was down, I put an SI steering wheel on my HF..
Im getting an alignment asap.. but is this strange? or usual for a car in need of an alignment.
Old Sep 26, 2002 | 04:23 PM
EL Vap133's Avatar
Default Re: holding my steering wheel 90 degrees (djay86)
it might be since your car was wrecked..... have you checked your suspension?
Old Sep 26, 2002 | 06:30 PM
Jared's Avatar
You defnintely have problems, but you won't know until its on the machine whether parts replacement will be necessary or not.
Old Sep 26, 2002 | 07:10 PM
djay86's Avatar
Default Re: holding my steering wheel 90 degrees (Jared)
what kinda problems? DMANIT
Old Sep 26, 2002 | 07:13 PM
matt j's Avatar
coulda bent the frame and that will cause it and the struts might be screwed along with a bunch of other things get it on a machine and check it out
Dezso3
Honda Civic (2006 - 2015)
Dec 11, 2015 08:57 AM
easyFOsheezy
Aug 25, 2010 12:26 PM
VTEC_Du_Ma_Mai
Feb 18, 2008 06:59 AM
Clutchmasta55
Sep 13, 2005 08:58 AM
b e e
Nov 19, 2004 11:04 PM
