rear camber kit squeaks???
Old Mar 11, 2011 | 12:32 PM
eat_sleep_ej1's Avatar
Default rear camber kit squeaks???
ok I got skunk 2 rear camber kit for my DB.. everytime I go on a bumpy road or when my car is bouncing up n down my rear camber squeaks.. I need to make it stop any suggestions?? I tried spraying lubricate rust spray and that didn't help.. please help!!!!
Old Mar 11, 2011 | 04:29 PM
Default Re: rear camber kit squeaks???
bump!!! plzz help
Old Mar 11, 2011 | 04:35 PM
TunerN00b's Avatar
Going out on a limb here and making an assumption, but you need to use the correct lube for polyurethane bushings to stop the squeak. And even then, it will come back again later, and then you'll need to clean and lube them again, and again, and again...
Really, the correct solution is to ditch the camber kit and put the stock control arms back on the car. They aren't needed for Integra anyway, unless you're trying to force fit wheels that don't fit.
Old Mar 11, 2011 | 05:08 PM
mr crick's Avatar
It could be your shocks that are squeaking kind sir. mine are trashed and make noise when they are extended.
My JDM EJ8
Mar 16, 2008 12:24 PM
stock99si
Jul 16, 2007 09:07 AM
dixie Normas7
Sep 8, 2006 11:17 AM
bartek_b
Oct 7, 2003 04:45 PM
Denny
Dec 15, 2002 07:22 PM
