4 th gen prelude problem gurus help
Ok so the other day I did a clutch swap in my 4thgen n put it all together check the lines hooked up all the lines n filled the necessary fluid so I put it on the ground bled the clutch line got pressure n when I go to throw it in gear its strugglesn as soon as it hits in it dies.now when I turn it off n put it in gear n start it with the clutch down the car moves .now the question is what is it.?!?
Have you tried adjusting the pedal throw? Go under the consol, by the pedals. Find the thing on the clutch pedal that looks like a CO2 cartridge. There are two BTW. One has a nut that locks the CO2 looking thingy. Losen that and adjust the pedal, not sure if you'll need to have the pedal closer or further away from the floorboard. Good luck.
Jus recently tried messinwith it again n right before I engage the clutch the pedal it vibrated really bad before its actually open also should have mentioned its a h23 I need this car done in the .next few days any other options or opinions would be greatly appreciated thanks HT
ls95hatch
May 24, 2003 09:34 PM
