Y7/Y8
In Process Starting A Mini Me Build Got Everything I Needed From
i have
y8 head
itm
y8 trans
y7 block
OBD2A-OBD1 jumper
ECU
http://www.jdmuniverse.com/forums/view_minime.html
My Question Is Do Need
Y8 cam gear
Y8 dizzy
If U Have Suggestions Let Me Knw
i have
y8 head
itm
y8 trans
y7 block
OBD2A-OBD1 jumper
ECU
Y8 cam gear
Y8 dizzy
Try the FAQ. 4 links there for mini-me swaps.
If you check in YOUR link he remove the distributor, sets it aside and reinstalls it. So if you're following that write up just do everything that they did and try not to second guess. It also said they used the Y8 cam gear.
Maybe re-read that DIY a couple of times before you attempt this.
Civicman86
Jul 10, 2006 08:08 AM
