Suspension & Brakes Theory, alignment, spring rates....
Springs Sagging
Old Mar 11, 2011 | 07:31 AM
nightscream's Avatar
Default Springs Sagging
I have a set of Neuspeed Race springs on OEM shocks in a 98 DC & Drop Zone Sport springs on Drop Zone non-adjustable "Race" shocks in a 92 EG. I have noticed both cars seem to sagging in the ***!!! Neither set of shocks is blown in either car. I actually took the rubbers out the front shock cup trying level out a little. Anyone have or have had this problem with these type of springs or other types of springs... Any ideas on how to fix???
Old Mar 11, 2011 | 10:35 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Springs Sagging
is the front kinda high? were the springs switched around?
same wheel/tire size front and back?
Old Mar 11, 2011 | 11:56 AM
TunerN00b's Avatar
How are you measuring? The best measurement is from the side jack points, not the fender gap.
An even drop will look lower int he rear, due to the fender shape. The front opening is larger, to allow the tires to turn. If you want it to look level, you want the front around 1/2" to 3/4" lower than the rear.
If you just want to adjust it without buying anything, do the "shock fork trick" in the front for a slight additional lowering and see if that gets you where you want it.
CivicFTW
Suspension & Brakes
Aug 13, 2010 06:59 PM
rEnZ94tEgGy
Suspension & Brakes
Nov 4, 2008 07:23 PM
kloscivicsi
Honda Civic (2006 - 2015)
Feb 1, 2008 06:14 PM
