Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
crower cams and AEM Fuel & Ignition Controller
Old Mar 11, 2011 | 05:53 AM
van6232's Avatar
Default crower cams and AEM Fuel & Ignition Controller
hi, everyone.
im in need of some insight. I am torn between the crower stg 1 and 2 cams.
i would really like the stg2 just because itd be that much better but i understand that the idle gets alittle funky.
so heres my questions
would the aem f/ic work for this app?
what kind of difference would the stg2 do over the stg1 for power and drivablitly?
and lastly has anyone driven the stg2 without tuning and had no problems? (unlikly i know but had to ask)
Old Mar 11, 2011 | 02:31 PM
sdaidoji's Avatar
Default Re: crower cams and AEM Fuel & Ignition Controller
search:
https://honda-tech.com/forums/showth...ghlight=crower
https://honda-tech.com/forums/honda-civic-2001-2005-78/stage-1-cams-2844103/
Old Mar 11, 2011 | 02:40 PM
van6232's Avatar
Sweet. Thanks. Funny I never seen that one before.
20hp that's good! On a stg 1!
Anything about the aem f/ic?
Old Mar 11, 2011 | 02:52 PM
sdaidoji's Avatar
haven't you already posted here? Page 2 bomerman is informing stage 2 and hondata
post #43, after your post.
Old Mar 11, 2011 | 02:56 PM
van6232's Avatar
Yes but this is a different unit. I was just wondering.
Old Mar 11, 2011 | 03:07 PM
sdaidoji's Avatar
Meaning you already have the AEM?
Anyway, post #43 informs that the only way to get idle is hondata.
Old Mar 11, 2011 | 03:50 PM
van6232's Avatar
Nope nothing yet. I got alittle behind on the build. But still on a budget.
Old Mar 11, 2011 | 05:44 PM
MindBomber's Avatar
If your build is serious enough that your looking to add stage 2 cams get Hondata, if not, stick with stage 1 cams.
Old Mar 11, 2011 | 06:01 PM
van6232's Avatar
I'm pretty serious but its alittle slow going. I wanna know if the ae$ f/ic will get me by for now if I decide with the stg2
Old Mar 11, 2011 | 06:11 PM
EM2abe's Avatar
If you get it right, the first time, then you don't have to worry about it later...
Old Mar 11, 2011 | 06:15 PM
van6232's Avatar
That's true. Your response is why I want other opinions keep em coming. Lol
Old Mar 11, 2011 | 06:40 PM
MindBomber's Avatar
Since your serious then I'd save for Hondata now and once you get that start saving for a stage 2 or 3 cam. If you go for the piggy back AEM f/ic you won't be able to extract nearly as much power from the cam upgrade as you would with with Hondata.
Old Mar 11, 2011 | 08:29 PM
sdaidoji's Avatar
Originally Posted by van6232
keep em coming.
come on...
Is there anything else to be coming?!?
He meant - go for hondata and fugget the AEM... (that coming from a noob like me :D)
Mindbomber, go take a nap - you need to work on UR K20 swap
Old Mar 12, 2011 | 04:59 AM
van6232's Avatar
Thank you mind bomber. That's more of the answer I was looking for.
What kinda of gains would kpro and stg2 net me?
Old Mar 12, 2011 | 08:30 AM
sdaidoji's Avatar
you really refusing to search yourself, right?
https://honda-tech.com/search.php?searchid=1369825
Old Mar 12, 2011 | 09:45 AM
van6232's Avatar
Listen man. You don't have to be rude about it. It was just a question. I thought it was pretty self explanatory that I was wondering if anyone knew of someone that had it dynoed and wasn't 5-6 years old! And your link didn't provide anything. Came up with no result.
Old Mar 13, 2011 | 01:15 PM
sdaidoji's Avatar
refusal to search is much worse. very rude and selfish.
proven for the fact that no other did reply since.
proven from the fact that you relied on my link.
our cars are much older than 5-6 years, so data still applies.
and note that most of your questions were replied - from a noob :D:D:D
And i have not seen any of these threads until now
difference is I am not lazy :D
Old Mar 13, 2011 | 02:24 PM
van6232's Avatar
And part of the reason you haven't seen any of these theards for a long time is because it was with a new unit to control them! I have seached even before the posts, I have searched lots! I know about brommerman and the other guy. If you actually read I was looking for info on the new unit and mindbomber gave me that. and while I had the opportunity I just threw the question out the if anyone knew of anybody has done it recently tell me what's the harm in that? You have no right to call me lazy at all. You have no idea how many threads I've searched and hours I've put in searching. If you don't know don't respond! That's why I don't post on other ppls threads much. I know my car but everyones ideas are different and everyone has there own opinions. Which is fine. But if you can't answer my question properly, like mindbomber did, then don't!! This has become a waste of time because your trying to "teach me a lesson" and are failing! It was a valid question! end of story!
Old Mar 13, 2011 | 02:25 PM
MindBomber's Avatar
Cams thrive on supporting mods, so I'm assuming you have I/H/E already, add Hondata and a stage 2 cam and I think you'd be in the 140whp range.
I've heard of stage 3 cams on a turbo'd d17a2 netting 75whp and its possible to use them on a DD D17 without issue on a car with hondata, but for those to be beneficial you need to either run higher compression pistons (the gx for example) or be turbo'd. I've also heard of stage 2 cams causing idle to run so rough with the lesser EMS systems that people stall at lights, so the tune and ems is really important.
Heres a good review of stage 2 cams that I have in my book marks.
http://www.civicforums.com/forums/2-...xperience.html
Old Mar 13, 2011 | 02:29 PM
van6232's Avatar
Perfect!! Thanks again! I do have i/h/e and flywheel, pulleys and y8 intake mani.
Old Mar 13, 2011 | 02:37 PM
van6232's Avatar
Ya its the rough idle I'm worried about.
turbohf
Northwest (Sales)
Sep 19, 2014 08:56 PM
turbohf
Aug 8, 2014 06:33 PM
RetroGamer
11
Jul 30, 2011 05:28 PM
c1_sleeper
Mar 13, 2006 06:24 PM
matto2413
Oct 16, 2005 05:46 PM
