That bolt securing the top of the clutch pedal bracket?
Old Mar 10, 2011 | 08:52 PM
Linked's Avatar
Default That bolt securing the top of the clutch pedal bracket?
anyone know what the size and spec of this bolt?
i know it'll b over priced at the dealer, i may be able to find it at lowes etc.
thanks to all
edit. for an eg coupe srry
Old Mar 10, 2011 | 09:23 PM
itsnotfast's Avatar
Default Re: That bolt securing the top of the clutch pedal bracket?
I belive its a pretty much the same thread pitch and size as most of the other 12mm bolts used in our cars. (12mm being the wrench size not thread)
Old Mar 10, 2011 | 09:47 PM
NOFX's Avatar
H-T White Ops
If the part number is the right setup, you can figure out the dimensions from the part number.
Make-up of Part Numbers
Old Mar 11, 2011 | 05:18 AM
94EG8's Avatar
Seagull Management
8 x 1.25 IIRC.
Old Mar 11, 2011 | 09:02 AM
Linked's Avatar
thanks guys i found what i need i believe
NOFX when i matched up the part number : 93404-08016-08
i did find diameter and length, but not thread pitch, might have to take 94EG8's assumption and try it
dcraige
May 28, 2010 09:54 AM
blk90sihatch
Jul 8, 2006 01:23 PM
radeonboy
Apr 5, 2006 06:45 PM
ihaveamustang
Jul 3, 2005 04:29 PM
