help staring up 95 gsr
Old Mar 10, 2011 | 05:05 PM
kc_kc's Avatar
Default help staring up 95 gsr
i have a 95 gsr with 210 mileage on the car. my car die on me and i chang new starter, battery, Distributor. the compression is 240, 210, 210, 184.But when i check my spark plug, its smell like gas on the bottom of the tip. when trying to start, its miss fire and die. some one told me i have to chang my head gasket and not sure yet. any ideas out there yet. help plZ.....
Old Mar 10, 2011 | 05:09 PM
kc_kc's Avatar
Default Re: help staring up 95 gsr
i already check my spark which is new but befor that i chang the fuel pump. but i havent check my relay yet. you guys think its that.
Old Mar 11, 2011 | 08:16 AM
kc_kc's Avatar
any ideas?
Old Mar 11, 2011 | 08:23 AM
91_LS's Avatar
Check the timing and relay.
Old Mar 12, 2011 | 07:48 AM
kc_kc's Avatar
ok
Old Mar 12, 2011 | 08:03 AM
dntnedvtec's Avatar
You don't chang head gasket. You head gasket good. It be you timing. If not you timing, it you spark. You chang plug rite? you chang wire? what else you chang?
Old Mar 12, 2011 | 08:25 AM
94VTEC2TONE's Avatar
did you make sure your timing is dead on when you installed the distributor? and why do so many people guess at ****ing parts
Old Mar 12, 2011 | 08:55 AM
fcm's Avatar
fcm
Old Fart
If you can smell gas on the spark plugs, it is a good bet that the fuel system is working, [fuel pump, PGM-FI Main Relay, injectors].
Sounds to me like the problem is no spark, or spark at wrong time, [timing] I would confirm that valve and ignition timing is correct before replacing any more parts that may not need replacing.
I have to agree with 94VTEC2TONE, replacing parts is an expensive way to troubleshoot a problem, much better and cheaper to find the problem and fix it, replacing that part if necessary. 94
PS.. to be clear, you did mean 210,000 miles right, not 210????
Old Mar 12, 2011 | 05:21 PM
kc_kc's Avatar
ok check it monday thanks
Ef4doorwagon
Feb 9, 2014 10:02 PM
Blk_EJ1
18
Apr 11, 2007 07:32 PM
1990civichatchie
Sep 16, 2006 01:39 PM
naptownrex
19
Feb 10, 2006 07:41 PM
I3ackfire
22
May 14, 2004 09:50 AM
