How to take the alternator out???
Old Mar 10, 2011 | 03:06 PM
steadysupreme's Avatar
Default How to take the alternator out???
So i just removed everything from the alternator, but seems like it is so hard to take it out.
THere is this black metal brace and the axle in the way, how do you guys take it out??
Old Mar 10, 2011 | 03:47 PM
Default Re: How to take the alternator out???
Anyone? I am in the process of replacing it, but i am stuck~
Old Mar 10, 2011 | 03:49 PM
I need to find that sweet spot to pull it out i guess, is it near where the O2 sensor and underneath the oil filter?
Old Mar 10, 2011 | 04:07 PM
94eg!'s Avatar
#1 Super Guy
Loved
I know on my old CRX it has to go out through the wheel well. Once you remove a splash guard, there is a perfect space for the alternator to pass through. Perhaps the Integra is the same...
Old Mar 10, 2011 | 04:08 PM
I wish i can too, but unfortunately not~
Old Mar 10, 2011 | 04:17 PM
330R's Avatar
I have not removed the alternator, so I can't give any pointers, but this might help
Good luck
Old Mar 10, 2011 | 04:26 PM
I didn't even do 7 and 8, but the alternator is out of the bracket already, just have to wiggle it out and now is free.
But you have to get the alternator OUT of the CAR, it is still stuck in that area now.
Can you also post the "Adjust belt tension" procedure?
Old Mar 10, 2011 | 05:03 PM
330R's Avatar
Old Mar 10, 2011 | 05:04 PM
1998GsRIntegra's Avatar
This probably won't help you, but it might be worth mentioning. I have taken the bottom alt. bracket off along with the drivers side axle on a b18c5 swapped crx to remove the alt. You may consider something along those lines.
Old Mar 10, 2011 | 05:05 PM
330R's Avatar
Maybe doing 7 & 8 will provide the space to lift the alternator up and out?
Old Mar 10, 2011 | 05:11 PM
7,8 ain't a problem at all, like i said, i have the alternator physically out of those brackets already.
is sitting on top of the axle now~
Old Mar 10, 2011 | 05:14 PM
330R's Avatar
You're welcome
Old Mar 10, 2011 | 05:29 PM
ekcoupeh22's Avatar
I'm pretty sure it fits between the body and the manifold I was trying to think it's been a while since I did one
Old Mar 11, 2011 | 08:53 PM
Black R's Avatar
25 Year Member
Remove the axle iirc.
Old Mar 11, 2011 | 09:19 PM
Ultraspeed DC2's Avatar
He might have the Intake Manifold Bracket in the way
Old Mar 11, 2011 | 09:32 PM
shahriar35's Avatar
I heard if you take a pry bar and use it to push the engine forward, then your axle should fall out from the bottom. This is w/ stock mounts of course.
On my 87 CRX the best method was removing the brake MC and moving it to the side and you could bring it out from the top.
Just options. The first one wont hurt your engine as long as the pry bar sits properly
Old Mar 11, 2011 | 09:41 PM
Yup prying between the subframe and tranny mount i think, then alternator will drop out. But yah i ran out of time and put everything back together yesterday, gonna take it to a shop on Tuesday.
Old Mar 11, 2011 | 09:42 PM
Oh i am sure the removal of MC will work too, just seems too much work for me at the time.
Old Mar 11, 2011 | 09:43 PM
shahriar35's Avatar
dont take it to the shop. finish it! You know the method now. Save the money and buy yourself some new tools instead.
Old Mar 11, 2011 | 10:41 PM
PaulMc's Avatar
Painfully Stupid
You need to remove the drivers side axle and go about removing/installing it through there. It will not fit out the top. I recently went through the same thing and found out the hard way. On an EK you can squeeze it in/out the top if you remove some minor things, but I wasn't able to on my ITR.
Old Mar 11, 2011 | 10:50 PM
IamVtec's Avatar
taking out axle is the way sir
32mm
17mm
14mm
Old Mar 13, 2011 | 03:46 PM
IN VTEC's Avatar
I did it on my daily ls by removing the axle and int shaft. Took about an hour total on a lift.
Old Mar 13, 2011 | 11:23 PM
Can you specify all those are? I guess i have to borrow a 32mm socket.
32mm
17mm
14mm
Old Mar 14, 2011 | 01:23 AM
b18cvtek97's Avatar
i did it without taking out the axle. just mess with it a bunch and it will come out
